How to hook up a denon avc 500amp to a denon avr 3808ci receiver?
How to hook up
  • Rocky Degelman Nov 02, 2012
    You can not hook up a reciever to a indegrated  amp, You will do damage to both of them,
  • 5,807 Answers
To add more power to your systems connect AVC500 amp AUX input to
AVR 3808C "Rec Out", or any of the audio "out" s you may want to
connect ( back of the receiver)
use RCA plug on both ends of the cable.
Enjoy and Have a nice day!
Posted on Nov 03, 2012
  • james Nov 03, 2012
    this will work and not harm either unit.
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
SOURCE: hooking up an external audio source (IPOD) to the Denon AVR 3803
sure
just get a cable with phono plugs to mini phone connector Radio shack has them
Connect teh mini phone to teh earphone jack adn teh phono plugs to the aux inputs
select aux and enjoy
Posted on Jan 07, 2009
SOURCE: NO GUI displayed
I had a similar problem with my Denon 3808 after it had the protection circuit tripped. First all I would get is a blue screen with sound, then after powering the unit off I got the display back, but all of the on screen GUI menus were gone. I could tell that the menu button worked because display located physically on the recever worked. I reset/rebooted the system (follow the directions in manual) and everything came back. Be aware by resetting the system any customization you have done will be lost. Hope that helps
Posted on Aug 04, 2009
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
RC-1068 preset codes
My self have problem with Denon AVR 3808Ci Receiver, the HDMI is doesnt work anymore, and I can not find replacement parts because receivers is out of date, very shame
Mar 30, 2014 | Denon AVR 3808Ci Receiver
I have a denon avr 3808ci and all of a suden im not getting sound frome sub.?
I'm having the same problem. Changed the wire from LFE to LFE input to the sub... I have a velodyne which has always worked great. Connected the sub with the original wire to my sony amp and it works great so it's the output on the amp. Any suggestions
Dec 08, 2012 | Denon AVR 3808Ci Receiver
How do I configure my denon avr3808ci to play 7:1
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
First, you must have all 7 primary speakers plus a powered suboofer attached. Page 9
Page 25 describes how automatic detection and adjustment is achieved. Page 28 for manual speaker setup.
Assign digital inputs. Page 39.
Then feed it appropriate 7.1-compatible material. page 40
Feb 28, 2011 | Denon AVR 3808Ci Receiver
Hi, how can i hook up a wireless 5.1 headphone to a denon avr-3808 using an optical connection. I can't find any optical output port on the denon amplifier.
My manual shows two optical outputs labeled "2 (DVR)" and "3 (VCR)" at the upper right of the rear panel.
It's unclear what will appear there when playing any particular analog source.
Feb 26, 2011 | Denon AVR 3808Ci Receiver
I cant turn off the closed caption on my avr-3808ci...???
The receiver has nothing to do with that since it doesn't actually tune the station or decode the video content.
Usually, it's the TV that deals with CC.
Feb 09, 2011 | Denon AVR 3808Ci Receiver
I need a Denon AVR-3808 Service Manual
try doing a google search for avr 3808 manual
also try going to denon.com if you need a hardcopy call denon tell them to send you one.
Feb 18, 2010 | Denon AVR 3808Ci Receiver
Digital projector is shutting down as soon as dvd
Hi make sure that in the projector menu it doesn't have an option to cancel "control" as many tv's with hdmi have the capability to receive command signals through the hdmi cable.
Also make sure that your receiver is set for hdmi signal you must designate which input you are using on the receiver and then tell it what type of signal you want it to use.
you may have just pushed a button that changed these settings somewhere along the way.
hope that helps
Dec 30, 2009 | Denon AVR 3808Ci Receiver
How do I set up outdoor speakers? I currently have them set on Surround B, but do not seem to be able to play them
Fined in owner's manual section about MULTI ZONE CONNECTION AND OPERATION. page 68. If you don't have a manual, download it from here : http://www.usa.denon.com/AVR-3808CI-OM-E_404A.pdf
Nov 08, 2009 | Denon AVR 3808Ci Receiver
I have a Denon AVR-3808ci. I am having problems hooking up my nintendo 64 to this unit. I am trying to use the 3 line cable which has left/right audio (respectively red/white) and audio (yellow). I have it...
If your amp is not upcoverting the picture you will have to come from the yellow monitor out on the amp to in on the tv,if you have no input on tv use a scart to phono convertor pluged into the scart socket.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Denon AVR 3808Ci Receiver
Playing mp3 files
if that is only a simple/usual reciever then you simply hook your laptop speaker out to any available line in of your receiver like aux, CD, DVD, video aux. but not the phono in please. you are just using the receiver as a simple amplifier for your laptop. is that what you need to know mam?
just post your comment if you have a different query. Regards/Reden
Apr 11, 2008 | Denon AVR 3808Ci Receiver
48 people viewed this question
 Grubhead
Grubhead
