Question about Toshiba Computers & Internet
Toshiba L775D has locked me out of bios
I need to get this fixed. Already did the battery thing. What next?
    Problem Solver:
  • 12 Answers
Boot from startup disk
Posted on Nov 02, 2012
2 Suggested Answers
archaeology
  • 662 Answers
SOURCE: I just bought a Toshiba Satelite L775D-S7206
joecoolvette's clarification is a good solution, but here's a how-to link with a wealth of detail:
http://www.ehow.com/how_6825686_install-verizon-um175-usb-modem.html
Posted on Oct 05, 2011
Toshiba satellite pro u400-130 bios password
  • The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS.
    To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out.
    Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity.
    After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computericon1.png, ideally, should no longer ask you for a BIOS password.
    It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password.
  • If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computersicon1.png that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Jan 26, 2013 | Toshiba Satellite Computers & Internet
Hello, I recently had a Toshiba Sattelite L455 that suddenly promped for a BIOS password on startup. There was never a bios password set for this laptop. So I found a workaround using the onboard...
You hit the correct jumpers for this model to remove the motherboard bios lock, which shows you have done your homework well. Toshiba, like Dell set a bios lock and HDD lock on some laptops for security reasons, often when the cmos battery needs changing, it manifests itself.
As to why you got this request for a bios pass is very odd, if you did not change the cmos battery, however, removing the battery as you state would not fix the hard drive problem. The hard drive will remain locked and if, as I suspect, it is a security measure, you will not be able to remove it and externally access files or even format it by slaving it in another computer or docking station.
Your best solution would be to contact a Toshiba service centre and explain the problem and ask them for a bios unlock code. IF this was installed at the factory, they should be able to remove it (you WILL be asked to provide proof of ownership)
I have heard of some laptops being "time locked", which is where the time/ date settings in the bios trigger a request for a bios password for security purposes, but never actually seen this occur. This might explain why the bios pass request appeared randomly as it did. There is the possibility that this was caused by a virus, although, again, I've never heard of this happening.
Jul 24, 2011 | Toshiba Satellite L455S5980 Notebook
Password bios toshiba 4000cdt
If you've forgotten your BIOS password, or if someone has changed the password on your Toshiba laptop without your permission, then there are a couple things that you can do to reset the password and access your computer.
Reset the CMOS
· The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS.
After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computer, ideally, should no longer ask you for a BIOS password.
Use a Backdoor Password
· If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computers that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Dec 06, 2010 | Toshiba Satellite 4000CDT Notebook
Laptop only runs on battery even though p/s is plugged
Curious problem. Let's start. I don't think that the mobo is responsible for the problem.
  1. How much time does the battery in full charched condition can hold Toshiba at power on mode?
  2. Is it possible for you to use a multimeter (voltmeter) to check some things for me?
Stelios.
Feb 22, 2010 | Toshiba Satellite A75-S206 Notebook
Hi, I need some help (BIOS locked)...
ok i found a couple more things...apparently you dont have to remove the battery.. I found this site that tells you two "jumpers" (solder squares) C88 i believe under the network card. But if you follow this link and follow the directions it will get you going again.
I don't know exactly at what stage you are at and i hope i didn't cause any trouble but this normally is how we take care of this problem. Unless once in a blue moon we come across one like this.
http://www.paralaptop.com/toshiba/fixing-bios-password-locked-on-toshiba-satellite-a105-s4014.html
Jan 17, 2009 | Toshiba Satellite A105 Notebook
Toshiba A215-S5818
It looks like you will need bring your laptop to a Toshiba Authorized Service Provider since this problem is already posted on Toshiba's website.
May 21, 2008 | Toshiba Satellite A215-S5822 Laptop
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
