SOURCE: ILO 26'' HDTV is froze on a single channel....
my brother your problem is a technical problem, from what your are explaining it is not your remote control the problem is with your tv your audio amp or audio occillator is having a component problem ,in that the ic or transistor that controls your audio is either having a leak or is out right faulty have it checked out by a tech if you have a knowledge of electronics you can do it your self.by ordering the part.at this time i do not have a schematic on hand in order to tell you what is the part number in ordre that you can replace it.good luck.
SOURCE: Volume on Remote powers TV on and off?
This unit has upgrades available for this set. I am not at my shop now, but, I think the problem you described is usually cured by this upgrade. The set is under warranty, contact: 1-800-Samsung for a local servicer. If you need additional help, respond to this post and I'll reply.
SOURCE: cable quit working says no signal
if u are using the cable input make sure u are un chanel 3 , other way to connect the cable box is thrught the video 1
SOURCE: One channel only has no sound
can't focus the picture or tex on my new sanyo 32" lcd hdtv model dp32648
SOURCE: Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Testimonial: "Thanks for the info! Very helpful!"
