Question about Dynex RC-401-0A Remote Control
Dynex remote wont work
Wont turn on television
How do I find the remote code for my dynex TV?
Remote Control Codes For Dynex TVs ' Codes For Universal Remotes
codesforuniversalremotes.com/remote-control-codes-for-dynex-tvs/
  1. Cached
  2. Similar
5 digit remote codes for Dynex TV = 10463 11463, 11780, 11785 ... with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc... Do you ...
RCA : Remote Code Finder : RCRN03BR : TV
www.rcaaudiovideo.com > Remote Code Finder
  1. Cached
  2. Similar
Durabrand, 10463, 10178, 10171, 11034. Dynex, 11463, 11785, 11810, 12049, 12184. ESA, 10171, 11944, 11963. Electroband, 10000. Electrograph, 11755.
Dynex TV Remote Control Codes
https://www.dynexproducts.com/remote-control-code
  1. Cached
Here is a listing of the most common Dynex TV codes for universal remote ... PHDVD5: 115; Phillips PMDVR8: 115; RCA RCU807: 135; Rogers DCT3250: 0463 ...
Universal RCA remote code needed for DYNEX tv [Solved] - Fixya
www.fixya.com/support/t8402745-universal_rca_remote_code_needed
  1. Cached
  2. Similar
Feb 22, 2011 - Hello Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv. Codes are 11463, 11810, 12184. code for my dynex Google Search
Dec 22, 2016 | Dynex Televison & Video
My DYNEX 32" wont give me any sound from remote or tv but changes channels
remotes do not have speakers in them and you might have turned MUTE on . having no way to see it personally there is not much we can do
Aug 03, 2016 | Dynex 32 in. LCD Flat-Panel HDTV
How do I turn my Dynex 40'' LCD TV 1080P on with out the controller?
Have the remote tested----our shop uses a tester--if remote is bad we usually can fix it for 10 dollars or less.
A digital camera with a LCD display can also be used in a dark room--remote pointed at it and buttons pressed---camera display will flash faintly in response.
Failing that try to locate a replacement remote (good luck with this brand).
May 16, 2012 | Televison & Video
I would like to program my Sony remote RMT-D187A to work a Dynex television but I cannot find the code to do so.
The Sony RMT-D187A cannot be programmed for a Dynex television. The brands supported according to Sony are: GoldStar, Hitachi, LG Mitsubushi / MGA, NEC, Panasonic, Philips, Pioneer, RCA, Samsung, Sharp, Sony, and Toshiba. Sorry, but it wont work on your TV.
Information found here: http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMTD187A
May 05, 2011 | Televison & Video
My 55" Dynex lcd TV
take it back.......could be the power supply board....
cheers
Apr 17, 2011 | Dynex Televison & Video
Dynex big screen tv stopped working won't come on with the remote of the botton. Only a little over a year old
The same exact thing just happened to me. I was watching tv and it just turned off by itself and now it wont turn back on. I've also only had mine a little over a year. The red light is on at the bottom left hand corner, but it wont turn on at all. Hopefully we can find an answer to what is going on!
May 21, 2010 | Protron PLTV3250 32 in. LCD Television
Progamming code for DYNEX t.v. w/ brighthouse cable remote
Do what I did...
Turn on TV
Press TV on the remote(will blink once)
Press and hold setup until tv button blinks twice
Hit 991 tv key will blink twice
Aim remote at tv press power button once
Press the Chan + key over and over until tv shuts off.
Same instructions as the manual
Jun 18, 2009 | Televison & Video
My t'v wont read my remote!
You will need to call the Dynex customer support and ask them for help with this problem. The problem sound like the television is having a problem with the main read controller for the remote control. This is a problem for a service center.You can call Dynex customer support at this telephone number 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of your television and the problem you are having with the remote control reading circuit. I hop this information helps you with your problem.
Apr 12, 2009 | Dynex DX-LCD37 TV
Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
Jun 26, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex RC-401-0A Remote Control Logo
32 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
