Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Saeco Barista Italia Digital won't stop calling for prime even though it primes just fine.
After descaling, it calls for prime. I have run 4 tanks of water through the prime and it still indicates that it "Needs to prime."
mirran
  • 515 Answers
SOURCE: Saeco Digital Italia steam knob
Take off the top and you will see the steam valve, try to mount the parts again.
Best regards
/Mirran
Posted on Sep 09, 2008
  • 9 Answers
SOURCE: our Saeco italia has an error message: Need to
i had this same problem and it turns out a small mineral deposit was lodged in the water line, right before it went in to the second heater (to make steam). The cost to repair and shipping was pretty high, so i fixed it myself and it's not too hard. You can try de-scaling. If you want take the water line apart, let me know and I'll walk you through it.
Posted on Oct 30, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Italia Digital Barista Fully Automatic Coffee Machine: the fill grinder light comes on (Saeco Italia,,not...
The grind might be set too fine.
Posted on May 20, 2010
EsWorld
  • 1618 Answers
SOURCE: Saeco Italia espresso machine. problems with water
To prime the pump run the hot water cycle for a few seconds, also when inserting the tank on the machine make sure it slides down the back making contact that will help the reed sensor, find the magnet in the float.
Posted on Sep 18, 2010
  • 1089 Answers
SOURCE: My Starbuck Barista Italia Digital
Hi
This is one of my tips.
http://www.fixya.com/support/r9604925-ventilate_go_away
You might call Seattle Coffee Gear.
Posted on Aug 07, 2011
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
Hi I have a Starbucks Barista Italia Digital that has been sitting in storage for over a year. When I try to prime the pump, it makes a noise like it is trying, but no water comes out. I have tried...
You could have a seized water pump if you haven't been descaling regularly. Take the pump out and disassemble, clean, reassemble. Work carefully as there are several small parts.
Feb 08, 2011 | Starbucks Saeco Italia Digital Barista...
Saeco Italia espresso machine. problems with water light on even though water tank is full. Not sure how to get water flow and/or prime the pump.
Sep 18, 2010 | Starbucks Saeco Italia Digital Barista...
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Best regards
/Mirran
Sep 09, 2008 | Starbucks Saeco Italia Digital Barista...
"NEED TO PRIME" alert is on. Have run a couple of tanks of water through the wand making hot water, but still says NEED TO PRIME. The pressure on the water seems a little lower than normal. Tried to...
That message indicates that water lines may be dirty. How long ago or how often had you descales your machine? If you have not routinely descaled then the water lines have to be cleaned ( by opening the machine) manually and/or replaced. Another possibility if you have been descaling it regularly, is that a water line may have small crack. And yet another possibility is that the pump may be going bad and/or the flow meter is clogged ( needs cleaning and/.or replacement). Best suggestion at this time is to have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 11, 2008 | Starbucks Saeco Italia Digital Barista...
Need to Prime
Something was in the water lines and the force of the pump pushed it through. Make sure from now on you descale your machine regularly.
May 18, 2008 | Starbucks Saeco Italia Digital Barista...
Can't prime new machine
brand new machine you put water in the container prime it with turkey blast open the valve on the side off machine and it still does not work tank good for warranty cheers
Jan 21, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco italia error
What happens when you open the knob on the right? It may just need priming.
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
57 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
