Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I recently did a self clean. Now I have a beeping F7 error code.
Now everytime the oven has power going to it - it beeps, then goes away for about a minute, then beeps again, a vicious annoying cycle. In this mode, I cannot seem to use any of the other stove or oven functions, including clock, bake, broil or self clean. I hit the buttons and nothing happens. The only button responding is the Clear/Off button which make the beep go away for a little while. (I cannot do the power off for minute #8+Cooking Time+Delay Start for diags either.) One thing I have noticed since the self-clean cycle, is that the touchpad display looks a little warped, almost as though it was heated. My questions: Is this a touchpad/keypad issue or a control board/ERC issue? Also, if it is either of these, can I replace these myself without causing further damage. I am a repair tech for computers, printers, and A/V equipment, so I do know how to handle ribbin cables, circuit boards and how to properly seat connectors. I see a few screws on the back of the unit that will probably give me access to the keypad assembly. I don't want to touch anything though until I get some sort of guidance from someone more experienced.
    Problem Solver:
  • 15 Answers
In order to rectify this problem you wold have to replace the clock/control unit.But as you say that you are tech.try this on the back panel of the clock there is generally 4 wires,basically the clock unit is just a switch.there will be 2 of these wires the same colour connected tto a small rectangular object known as relay,with the mains power turned off disconnect these wires from the board and connect them together.this will stop the noise and the use of the clock but will allow the use of the oven. good luck.
Posted on Jul 18, 2007
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
''F7'' Error Code
HI. This is the result of a failed function key. This is an integrated part of the main control board. Unfortunately, this is not repairable, and the main control board will need to be replaced, asap.
Dec 20, 2009 | Kenmore Ovens
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
F7 code on a JTP12 oven range; sometimes it beeps, but now it does not beep. The clock is working; the other buttons do not work; the oven does not work. The code goes away once ot twice every year for...
This is a common problem with an easy fix.  I have fixed mine with the following solution, and it is still going strong
http://www.fixya.com/howto/h155060-dreaded_f7_error
good luck!
Dec 20, 2008 | GE Profile JTP18 Electric Single Oven
F7 error code
f-7 means either the touch pad is stuck or a relay on the control board is stuck. if the code came up while the oven was not being used then the touch pad is shorted. if it came up while in use then the controlboard is bad
Nov 22, 2007 | GE JGRP17 Gas Single Oven
F7
No F7 in my tech sheet Could it be a F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad if you want to do it yourself let me know...
Aug 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
148 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
