Question about Sewing Machines
New Home 434_434D serger, will not connect threads to make stitches
  • Sewing Machines Master
  • 7,365 Answers
Try changing the needles--make sure the needle are the correct
one for the fabric being sewed
make sure the machine is threaded correctly
this link has parts for the serger and a manual
http://www.sewingpartsonline.com/janome-434D-sewing-machine-parts.aspx
Posted on Nov 03, 2012
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Posted on Mar 06, 2009
  • 15 Answers
SOURCE: I have a white superlock 228 jaguar serger problems with right needle
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Posted on Sep 09, 2008
SOURCE: my white speedylock serger 1634 thread keeps getting in knots
i have the book and it says thread from inside out, inside looper (upper) then lower, then thread the needles, first right then left.  I have found that it does not matter if you thread the needles or loopers first but that you should try to thread from inside to out.
Posted on Feb 25, 2009
Zenqi
  • 208 Answers
SOURCE: My brand new Kenmore serger
The loopers must be threaded before the needles.
Make sure that the needles are not threaded. Thread the loopers and have the loose ends behind the presser foot. Then re-thread the needles and place a scrap of fabric under the foot and sew. Make sure that the edge of the fabric is not to the right of the plate, but where it would be if the knife had cut it.
Posted on Jun 17, 2009
  • 46 Answers
SOURCE: My Evolve serger is skipping stitches while using
First, change the needles making sure to use the el705 needle system. Second, make sure the subsidiary looper is engaged properly (plugging up the upper looper hole). Also make sure the needles are all the way up in the machine. This should do it or it may need to be adjusted but the Evolve is a very, very reliable machine. Hope this helps...
Posted on Nov 27, 2009
Testimonial: "Thanks I am going to try this as soon as I can, but right now occupied with a job with my industrial machine. My only issue may be with the needle."
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Make It Handmade Perfecting Serger Overlocker Tension
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
I am new st this but my serger will stitch but the left needle thread will not join the others why ?
It could be that the serger has an independent left needle. Some older sergers were. Built like this so that a single stitching line with an overcasting stitch beside it. This is so that you can stitch a garment with a single stitching line and an overcast edge beside it instead of having to do two operations.
Oct 10, 2014 | Sewing Machines
My serger won't stitch
Be sure you have new needles inserted correctly, threaded in order loopers then needles, check with diagram on machine or in manual to be sure correct. Still not working usually a sign of timing problem. Requires technician trained on serger repair.
Jan 09, 2014 | Singer 14SH654
How do you lengthen stitch. The stitches are so close together it looks like a satin stitch. I have no manual for it. thanks!
your machine should have a stitch length dial on the right hand side above the flywheel, it might have numbers from 0.5 to 3 or 4, higher number for longer stitch (effectively this moves the foot and feed dogs faster in relation to the needles to make the stitch longer).
If you have the Serge Pro SW432 that your enquiry is linked to and you have not used a serger before, then definitely get hold of the manual, you will need it. Sergers are very different to sewing machines - once you've mastered one, its easy, but there is a learning curve.
Firstly, ALWAYS extend the thread aerial up, you'll see loads of images of sergers sitting nicely with the aerial in the lowered position, great for moving them to avoid damage. But they won't work well, a serger seams at 1500 stitches per minute and the thread streams off the cones so you need to ensure there is a good clear feed via the aerial to the tension dials.
Buy good quality thread cones and keep it out of the sun and dust. Cover your machine when not in use (lower the aerial first). You could start with white, grey and black thread as this will cover a lot of fabric prints/colours etc. To change thread colour, you will need to cut and knot on the new thread for the two loopers (right hand side cones) - do this about 6 inches above the first thread guide, and then chain off to feed these through down to the needle plate, when you see the new colour come through okay, stop. Repeat the process for the needle thread or threads (3 or 4 thead depending on what stitch you are sewing) but stop chaining when the thread knot is above the needles. Stop, loosen these tension dials and pull the thread down, cut out the knot with scissors and thread the new colour through the two needles. Use threading wires if you have them, or tweezers. Pull both these and the two looper threads together under the pressure foot, lower the foot, turn your tension dials back to 5 and chain off. The thread sequence is important, mostly top looper, bottom looper, then needles, this is so much easier demonstrated than explained.
If you can find a classroom/shop offering overlocking user lessons, go take a couple, its well worth the money. Otherwise go to you-tube and watch all the videos you can search on sergers, threading, etc.
Good luck with your serger, please respond with 4 thumbs if this has been helpful to you. :-)
May 19, 2011 | Simplicity Serge Pro SW432 Mechanical...
Hi i just got a new brother 1034D serger. And I'm
I found that I had to remove the stitch finger to thread the machine properly. Do remember to re-install it before starting to sew. If you are using 3-threads only, then remove and store the stitch finger.
Puzzled that this instruction is not in the threading section of the manual.
Jun 23, 2010 | Brother Lay-In Thread Serger Mechanical...
Hello I just got a new home My Lock 334D machine. It has Seized intermittenly. could we troubleshoot the problem & fix it together?
Un-thread and then see if the machine will run without thread.
If not, it needs to go into the shop for repair.
If it does, refer to the manual. Or, the guide that should be printed on the inside of the serger's door.
Raise the thread antenna to it's highest position. Keep it at this position when serging. If lowered for storage, and threaded, be sure the thread does not tangle around the antenna arms.
Raise the presser foot.
Open/set the tensions to zero.
Raise the loopers to their highest level - there may be an indicator mark on the side of the serger to match with a mark on the handwheel to help with this.
Start threading from the right to the left; upper looper first.
After threading, reset the tensions to a medium number, lower the presser foot and stitch a chain to test the stitching.
Serge a scrap and adjust the tension as necessary.
Once you get the serger working as it should - don't run out of thread. Tie off, open the tension, raise presser foot and gently guide the new thread through the threading process.
When changing the thread or removing the thread to store the serger, cut the thread at the antenna, leaving thread tails for tying off the new thread.
If you do not have Nancy Zieman's "Serge with Confidence", you will find it much more informative than the average serger manual.
May 01, 2010 | Sewing Machines
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Mar 11, 2007 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
