Question about Husqvarna Sewing Machines
Husqvarna viking 910 serger will not power on.
  • Husqvarna Master
  • 7,365 Answers
Check the power cord to make sure it's plugged into the machine
correctly
make sure the outlet is working
it's also possible that the on and off switch has gone out
it's also possible that the machine could have a hidden fuse, I
would suggest contacting viking customer service to see if there
is a fuse
here is a link for a manual
http://www.sewingpartsonline.com/instruction-manual-viking-905-910.aspx
Posted on Nov 03, 2012
  • sewingfun
    sewingfun Nov 04, 2012
    found the problem one of the plug in's on the circuit board was loose. Thanks
SOURCE: husqvarna huskylock 910 wont form chain while sewing
Are you sure the tension is right? You might need to push the thread hard against the track after leaving spool going into the machine (until it clicks). I had that problem also. Hope that helps.
Posted on Jun 27, 2008
SOURCE: my viking serger 905 wont cut
Sometimes the blades need to be adjusted. Lower them all the way manually to the bottom. The cutters if you look on the side should meet. If they don't' meet or if there is a small space then the upper cutter needs to be lowered.
There are screws that hold this in place. You might need a man to help since the screws on my machine are very tight!
Posted on Apr 10, 2009
  • 11 Answers
SOURCE: user guide Overlocker/serger Husquvarna Viking Huskylock 905
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Posted on Jul 24, 2009
  • 152 Answers
SOURCE: Won't form a chain stitch
You 910 serger doesn't have the option for a Chain Stitch. It is a 2, 3, or 4 thread serger. You can do a good number of different stitches but a chain stich is not one of them.
If what you mean it that it won't "chain off", meaning sew with no fabric beneath the foot as you gently pull the thread towards the rear of the machine, that could be for a number of different reasons. First, change the needles and unthread the machine and start over. If the threads are not exactly where they should be, your serger won't sew correctly. A great video on threading your machine can be seen at:http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
Posted on Oct 15, 2009
  • 152 Answers
SOURCE: Designer I software compatibility
You need the Husqvarna Viking software to turn those file extensions into the SHV format. It's about $400 at your dealer. Their web site does a nice job of showing its features. You get over 100 fonts and alot of designs too. You would open your current designs on a screen and then re-write them to the floppy or stick depending on your model of D1. It then sends the stitch information with the picture of the design to the floppy so your D1 can display the image. (The SHV format)
The VIP and HUS format don't carry the image file for your machine so it say's, "file not found", when you try to open them in your D1.
Posted on Oct 24, 2009
How do I thread the Husvarna 910 serger?
Hard to explain here. You will probably need pictures to show you exactly. If you don't have the user manual/guide, it should be available on the husqvarna viking website under 'Machine Updates' (bottom right hand corner of home page). From Machine Updates page, select All machines and scroll down until you find your machine listed. Also most viking dealers are familiar with this machine and should be able to help you thread it if you stop by their store with the machine. You can find a dealer near you by using 'Locate a Dealer' link at the husqvarna viking website
http://www.husqvarnaviking.com/us
May 31, 2014 | Husqvarna Huskylock Computerized 910
Husky lock 910 handwheel jammed
You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Jan 08, 2014 | Husqvarna Huskylock Computerized 910
How to thread huckylock 901 serger
The picture diagram works the best for this, it tells you how to tread for every different stitch that you want to perform. You have to thread it in different ways for every stitch so it is difficult to tell you in writing. If you visit your local Viking dealer they would be able to make you a copy and I'm sure show you how right there.
Jul 26, 2010 | Husqvarna Huskylock Computerized 910
I need to know how to thread my Viking Husqvarna Huskylock 905/910 This is a serger sewing machine and very difficult to thread. I have had this machine for quite a while and have not had the opportunity...
You have a great machine. These are hard to thread but once you have mastered it, you'll have many years of great use. The owner's manual has instructions, as well as the inside door of the machine (the door that folds down on the front bottom part of the machine. However, you might want to follow-up with your local authorized Husqvarna Viking dealer. Most are eager to help you even if you didn't purchase the machine from them. Some even have classes on using the serger. You might try several stores in the area. Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
One fundamental tip is to follow the color coding, start with green, then blue/navy, then red, and finally yellow. The sequence is work inside to outside with threading (green - blue - red - yellow). Do not try different order--especially with green and blue -- since the threads build on each other. I have switched yellow and red with no impact but green then blue is always the proper order.
Good luck.
Jan 20, 2010 | Husqvarna Viking 1
Just had new knives installed and it still won't cut heavier fabrics. I truly believe the repairman is not familiar with this particular Husqvarna-Viking serger. I'm looking for a company store in Port...
The dealer in port charlotte is located at 2421 Tamaimi Trail, their phone number is: 941-232-3555. If your last tech changed only one blade and you needed both changed, it's possible that the blade he didn't change, ruined the new blade he did change.
Oct 30, 2009 | Husqvarna Huskylock Computerized 910
Need power cord forHuskylock 435 serger and
That serger was made for Viking by the Brother company. Just about any sewing machine repair shop should be able to get you a cord and pedal. Call Viking at: 1-800-474-6437 to see if you can get a photo copy of the manual.
Oct 28, 2009 | Husqvarna Viking 1
I HAVE LOST MY POWER CORD AND NEED TO BUY A
You can try ebay but be sure to know what you are looking for since a lot of cords are very similiar.
3rd party vendors which might have it:
http://www.pd60.net
contact authorized Husqvarna Viking dealer and they should be able to order one from Husqvarna Viking. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
I need an instruction manual for a Husquvarna 910
https://www.2instructions.com/search.php?...HUSQVARNA...HUSKYLOCK%20SERGER%20910
copy and paste this link in your address bar to bring you to your manual site.
Let me know if you need more info
Sep 03, 2009 | Sewing Machines
Husqvarna serger won't sew - everything moves, threaded correctly, no results
re-thread and turn the wheel for the first few stiches, also check out this site Husqvarna Viking Sewing Gallery/Ultimate SEWING PlaceWe will gladly answer any of your questions on the Husqvarna Viking or SINGER ® sewing machines, Embroidery, quilting or sergers that we carry, ...
http://www.vwsewgallery.com/
Aug 28, 2009 | Husqvarna Sewing Machines
I would like to know where I could find a serving & repair shop
Use the dealer locator:
http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Sep 25, 2008 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
120 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
