Question about Ovens
I have just bought a Satchwell 70TH Thermostat but have no wiring diagram for it.
Bought a prima superchef oven, when I plug it in the electricity trip switch cuts off the power.
or a wire is touching the casing. If it is new, call the retailer. If it is secondhand call an appliance technician.
If it is a UK or Australian cooker, and the wires a fixed into terminals behind a cover on the wall, you have it wired wrong.
Big volts and amps can kill.
http://www.askmediy.com/wiring-diagram-for-a-stove-plug/
wiring diagram for stove plug AskmeDIY
Aug 21, 2016 | Ovens
How to wire t71th thermostat?
Try here, select thermostat model scrool to the bottom, wiring diagram available
http://www.macspares.co.za/stoves-microwaves/type-591035-71th-thermostat-6mm-shaft-bush-mount
Jun 04, 2014 | Ovens
Thermostat light flashing and none of the oven functions will work (fan, grill, heat etc)
An oven thermostat is a switch that opens and closes in response to the temperature it senses. It is typically found in the control panel, where a liquid-filled temperature-sensing bulb senses and maintains the internal oven temperature by cycling heat on and off.
Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  1. Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable back splash. Lift the backsplash, rest it on the cook top and remove the screws from the back splash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  2. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
  3. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
  4. To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire.
  5. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place.
  6. To install a new thermostat, reverse the disassembly procedure, transferring the wires individually from the old unit to the new.
Hope this was helpful.Thanks for using fixya.
Jan 26, 2011 | Ovens
Bake element will not shut off at set temp.
You need to check the oven cycle relay,
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located.
  3. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced.
  4. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Then you check the oven thermostat: When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Hope this information helped you.
Jan 14, 2011 | Whirlpool RBS275PD Electric Single Oven
Oven does not work and the elements are good no f codes and the probe was change?
Hello there:
  2. Access the oven thermostat, which is located in different places depending on the make and model:
    1. On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.
    2. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components.
    3. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel.
    4. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you.
    5. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  3. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
  4. Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
  5. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
  6. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
  7. To remove the thermostat:
    1. Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire.
    2. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place.
  8. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Jan 05, 2011 | Frigidaire Ovens
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Thermostat for kenmore oven wiring
Here's a link for you: http://www.partselect.com. You can put in your make and model and get diagrams of your appliance and see how things connect. Good luck!
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
118 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
