Question about Xerox Phaser 6120/YN Laser Printer
Paper size mismatch error
While printing using LTR paper, with printer set in LTR paper mode, printer prints on 3/4 of the page with the display saying "paper size mismatch"
SOURCE: Xerox Phaser 7300DN will not collate
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
Posted on Nov 26, 2008
  • 2072 Answers
SOURCE: Frequent paper jams on Xerox PE220
You have to spin them backward to get them into a good position to clean them, They will resist you, but just take it slow and clean them with alcohol or formula 409 type cleaner.
But what will often cause jams on that machine is the seperation pad that is located on the paper tray itself. It will get very slick and allow 2 or more pieces of paper to feed, It is a small gray to black pad on the middle front of the tray, about 1/4 inch wide and and inch or so long, If it is smoothe scuff it with some scotch brite then order one or two.
Google a business called "the parts drop" and call Britt, they should have the pads and rollers at a fair price.
Posted on Feb 09, 2009
jonb3838
  • 237 Answers
SOURCE: I am trying to print
The tray itself should have tabs on the side telling the type of paper look at those and see if there is anything broken off.
Posted on Feb 11, 2009
vincent721
  • 240 Answers
SOURCE: when trying to print from computers the message
double check the paper setting and margins set up on your computer.
check the printer properties
Posted on Mar 23, 2009
  • 2072 Answers
SOURCE: M20/Ms0i WorkCentre display "Paper Size
the settings on the print driver and the machine do not match.
  1. ress the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until the required paper tray is displayed; either [Tray 1 Size], [Tray 2 Size], or [Bypass Size].
  4. Press the [Enter] button.
  5. Press the [Left] or [Right] arrow button until the paper size loaded in the paper tray is displayed.
  6. Press the [Enter] button to save the setting.
  7. Press the [Stop] button to return to the Standby mode.
Posted on Jan 29, 2010
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
I have a brother hl-5250dn with an extra tray for legal size paper. I have a problem printing loan documents sent via swiftview or elynx. I can only print on letter pages or legal pages but not both and...
Sounds like your secratery's printer is set to ignore paper mismatch errors. It depends on the setting you have in your driver. Can you set your driver on your printer to ignore paper mismatch errors. If not when your printer errors, just try hitting the go button and it should print the document any way.
Sep 07, 2009 | Brother HL 5250DN Laser Printer
Qms 2200 paper mismatch error
Initial Thoughts
The problem seems to be a fault in a paper feed sensor. This would explain the size mismatch, since these sensors are how the printer detects the paper size. And, it would explain why printing starts two-thirds down the page, since these sensors are also used in timing where on the page to start printing.
However, a document passes through three software applications before it actually prints. And, any one of them could be causing the paper size mismatch.
Insight
Although paper sensors are usually low-tech and easy to remedy, they are often difficult to find and can sometimes be difficult to get to. Most such sensors are simple switches (toggles) and others are optical sensors that work like the electric eye of a garage door opening system. And, the solution may be as simple as a tiny piece of paper stuck on one of them. However, sensors such as these are quite numerous on this printer and can be hidden anywhere.
The three software applications I referred to are:
1. The document rendering application, such as Adobe Reader, Microsoft Word, etc.
2. The print writer. This is part of the device driver software package. It breaks up a print request and converts it to a standard format that the printer will always recognize and manages transmission of each page to the system spooler or directly to the printer.
3. The printer firmware. I'm not sure of everything this does related to the print stream. But, part of it must manage resources, such as ensuring the right size paper is being fed.
Jan 23, 2009 | Minolta magicolor 2200 EN Laser Printer
CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Dec 06, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Nov 01, 2008 | HP Photosmart C4280 Aio Printer
Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Error message 490 mismatch
mismatch occurs when printer paper settings and document page size are not the same, check document page size.check print driver settings.
Nov 21, 2007 | OKI C5200n Laser Printer
Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
Nov 13, 2007 | Office Equipment & Supplies
Xerox Phaser 6120/YN Laser Printer Logo
49 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
