Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore HE4T Elite F06 problems
I had the Sears service tech out 6 times and they could not figure out why the F06 kept flashing - especially on the heavy duty cycle - high speed spin - last 30 minutes of the cycle. According to them, everything was testing ok. I did buy the extended warranty (thank goodness) and Sears FINALLY did allow me to choose another washing machine. Hope this one doesn't have any issues.............
I'm not handy but for $30 and an hour of time I fixed my F11 Error code myself.
I took hi-res pics and created a step by step guide to help other folks in this predicament.
http://he4tf11.blogspot.com/
Posted on Jan 15, 2009
Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
Posted on Jan 05, 2009
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore Elite at the right front of dishwasher
Sorry to hear of your plight. My advice is to ask for a new machine under the lemon law since they cannot get it fixed. You can also try calling Whirlpool who is the manufacturer but they are likely to tell you to work with Sears. They were out under warranty and it has not remained fixed so the warranty should carry through since you called for service while still in warranty. I feel for the tech because it is frustrating to have a problem that you cannot find a cure for be the tech should also have escalated it to the tech support line for resolution. (I was a Sears tech for 21 years)
Sep 14, 2009 | Kenmore 15129 Built-in Dishwasher
HE4t Washer
"F06" is a Motor Speed error. The following link explains how to troubleshoot and some common causes:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The first step to troublehsooting should be to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches with the unit. If the error code reappears following a computer reset, follow the advice given in the link I provided.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Clicking sound.....
must likely something in between drum & basket or rear bearing going bad.call sears ask for service smart agreement it will cover rear shell with bearing &basket in warranty
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis Model# 110.27087603
I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
Oct 29, 2008 | Washing Machines
Front Door Seal/Baffle Replacement
I need to replace a baffle from inside my Elite HE3T. Do you have directions? Only 1 came off but when I order the new one apparently it only comes in 3, so show I replace the other 2 as well? (if I can figure out how)
Of course the part did not come with any! And Sears customer service is of no help and the technical people have not responded to me.
Thanks,
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
711 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
