Question about Sharp KB6024MW Insight Pro 24" Built-In 1.1 Cu. Ft. Microwave Drawer
Drawer tries to close and then opens
Drawer goes to shut then opens will not latch
  • Sharp Master
  • 9,098 Answers
I would suspect that a foreign object may have gotten in the pathway of the drawer, the drawer actuator is out of adjustment, or one of the door sensor switch is damaged, defective, or off its mount.
The service manual is at our site here.
You can order Sharp parts from Encompass here.
Posted on Nov 03, 2012
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: sahrp microwave drawer doesn't automatically
It will have a one year warranty.
I would contact Sharp for their nearest authorized servicer.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Posted on Nov 29, 2009
My brand new sharp microwave drawer oven will not stay closed. The close button closes it, but then it opens
To help you, I would need your full model number as shown on the tag in or or the oven. please e-mail me here
Dec 26, 2016 | Sharp Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to reset dacor mwo30s warming drawer
If for some reason you don't still have your owner's manual, you can find it here.
Nov 30, 2013 | Dacor MWO30S Millennia Series Warming...
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Sahrp microwave drawer doesn't automatically
Nov 27, 2009 | Sharp Microwave Ovens
Bosch range front glass smashed
open the oven door and look on the sides where the door meets the oven. also slide open bottom drawer and look where drawer meets oven. hope this helps!
Aug 29, 2009 | Bosch HMB402 Microwave Oven
Everything on my microwave works except it stopped heating food
I found this on another blog and it worked for me.
Model #KB6024MK, this is a Sharp microwave drawer that would open and close properly, but when started would not heat. These drawer units will sometimes close properly, but not enough to actuate the interlock switches to power the magnetron. A quick test is to turn the unit on and press in on the drawer handle while it is running. If you start hearing the low hum of the magnetron, the interlock assembly is out of adjustment. Removed the left side panel and gained access to the switch mounts to do a quick adjustment so when the drawer closes, the switches close properly to allow operation. It may take more than one adjustment to make it work properly so test it several times before reinstalling the side panel. It should work properly when the drawer auto closes and should not require any manual manipulation from the user.
Dec 06, 2008 | Microwave Ovens
Sharp KB6024MW Insight Pro 24" Built-In 1.1 Cu. Ft. Microwave Drawer Logo
537 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
