Question about Marshall MG100HDFX 100-Watt Amplifier Head
Bought amp with no footswitch
Need a wiring diagram for footswitch. Is it just stereo jack switching, or are there other components?
    Novelist:
    Champion:
  • 225 Answers
The schematic shows it as a standard 1/4 inch stereo plug. Wire the ground common to both switches (Channel and DFX), the ring to one switch and the tip to the other...I.E. ground (sleeve) to ring for one switch and ground to tip for the other. You'll have to experiment with which switch operates what function and label them accordingly.
Posted on Nov 02, 2012
MARSHALL FOOTSWITCH FOR DSL100 TROUBLES
Does your M foot switch work on the Fender? If you know how to use a multimeter you could check continuity by putting meter leads on plug of M foot switch(1 on tip, 1 on sleeve ) You should see a change in the multi meter when you depress switch. If so switch is good. Another easy test is with cap off a spare 1/4 plug -plug it in to foot switch jack.put a alligator or some such metal clip or wire and join(called short or shorting) the two inputs . If connecting and unconnecting results in switching then the foot switch is suspect. One fairly common thing is that foot switch and input jack are often sautered straight to a circuit board to save $ on production cost. Used to be all point to point where a wire was attached to 1/4" input and then wire went to circuit board or tubes. The wire has give, but not so with direct wiring to board. So the nut holding the 1/4" amp input gets loose(doesn't have to be loose for the following to happen) and a pull on the chord causes a break in the soldier and thus a break in the sound chain. Sometimes it will work intermittingly by putting a little pressure left, right, up or down on the plugged in plug. If so, it's the input jacks connection to the amp. If not it still could be that because putting pressure on plug may not be sufficient to affect a temporary reconnection. Since switch(the new one you made)works on Fender, but not Marshall I suspect the jack or foot switch circuitry past the input jack. If using some of the above the above tests leads you that direction,remove housing(unplug a/c power 1st ) inspect jack,wiggle it slightly see or feel a break then resodier from back side. You should be able to use the soldier already present without adding extra.
Sep 27, 2017 | Music
I have a VOX AC15C1 amp and bought a VFS2A foot switch. The foot switch right LED did not come on and I sent it back for a replacement. The replacement foot switch came and the right channel seems not to...
That supposedly is the correct footswitch for the amp... there may be a defect in the amp. Contact the factory support about this problem. Make sure you are FULLY plugging in the plug as SOMETIMES they feel like they are clear in but they are not.
Sep 19, 2011 | VOX VFS2A
Three button crate footswitch wires need to be refastened. I need a wiring diagram.
My mate's crate uses two stereo jack leads similar to 6.35mm guitar leads but stereo. You can buy them anywhere.
Sep 16, 2011 | Crate Cfs3
Input jack fell inside
Yes, the jack MAY actually be broken. It will need to be serviced. Run cables through the handle to avoid plugs from being yanked sideways and breaking the jacks.
Aug 23, 2011 | Roland Cube-20x (20w 8" Modeling Guitar...
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Apr 22, 2011 | Roland FS1 Footswitch Pedal Switch
I have a Marshall channel/dfx footswitch. The jack plug has been chopped off leaving me with a red, blue and yellow wire. Can you tell me where each one is soldered to on a replacement stereo jack plug?...
NEVER trust colors... with an ohmmeter you can tell which is the common lead by testing... find the lead that has continuity to EITHER switch independently... It is PROBABLY the blue one... this will be the "sleeve" of the plug. The schematic documentation is so bad the jack wiring cannot be decipered as to which contact is the tip and the ring. HOWEVER once you find the common of the switches and connect it to the sleeve you have only two choices for the other wires so just try them.
You can also take the back off the pedal to find which color goes to BOTH the switches... connect that one to the sleeve. Try the other two wires for proper operation before final soldering.
Apr 11, 2011 | Marshall Amplification Marshall Footswitch...
Hi , I have a Yamaha RA50 rotary amp ...what kind of stereo footswitch should I be looking for to suit this unit .Would a Peavey stereo footswitch do the job ? thank you , Michael
The footswitch just has two toggling buttons that connect either the tip or ring or both of the TRS plug to the sleeve. Very low-tech... make your own.
The buttons are alternate on-off action ones.
Feb 06, 2011 | Peavey TwoButton Stereo Footswitch
I seem to have the wrong cord on my footswitch as the female end on my amp is one of those computer types, How can i get around this?
The footswitch should be a 1/4 inch stereo type (TRS) plug to fit the footswitch jack of the MG250FX. It is a three wire connection.
Jan 06, 2011 | Marshall Amplification Marshall MG250DFX...
My 100hdfx has a problem switching channels. Both overdrive channels work fine but the clean channel is none existant. If you switch it to the clean channel and turn it up all the way you can faintly here...
have you tried the footswitch to change channels. also. my amp has to be in channel 2 position (with the button on the head) before i can use the footswitch. sometimes the input/footswitch jack wears out and you need to bend the internal tip/ring tabs of the jack to make better contact. also like on my fender amp, i had just a standard mono instrument cable going to my footswitch and it was acting wierd cause it needed a stereo instrument cable. one last thing on the grounding resistors on the pcb, they get hot and break the solder welds which messes with all sorts of stuff in amps. usually look like sugar cubes , cement resistor. 5watt usually under 1k ohm. check for bad solder welds on the pcb where the big resistors are and the switches/buttons and at the footswitch. there may be a bad ic or transistor for the channel swithing
Dec 30, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Fender Hor Rod deville footswitch
If the footswitch is not switching correctly, open it up and check for any shorts or a defective switch. Sounds like it's a problem with the switch.
Aug 14, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Marshall MG100HDFX 100-Watt Amplifier Head Logo
158 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
