Question about Frigidaire ATF6000ES Front Load Washer
Candy1682d/180 will not spin with clothes in drum, empty drum and will spin what's the matter
  • Anonymous Mar 27, 2014
    the middle spins but the drum want
  • Official Brand Answer
  • 4,342 Answers
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly, faulty pump, the timer or control board not communicating correctly.
Posted on Nov 03, 2012
2 Suggested Answers
SOURCE: when washing clothes...load size dont
check the water pump, that might be malfunction.
Posted on Jun 02, 2011
Why drum making noice when the cloths r in spin. but on empty drum it goes silently
Because the drum is out of balance with uneven clothes, or that the shock absorber springs are worn, broken or stretched. An empty drum has no load.
Mar 14, 2018 | Washing Machines
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
Sep 15, 2015 | Washing Machines
I have a WTW6600SW1 Whirlpool washer that stays unbalanced even when empty. How do I fix it?
A memo was issued by service matters to remove the counterweight on the base of the machine and add springs to stabilize lateral movement.
Jul 21, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't shift into spin
with a lot of the machines now they wont go into spin mode if the drum is not balanced properly, like say you had a load of towels in their, well it wont spin as its to unstable to spin without wobbling around so it simply stops at the spin cycle and does nothing, you can try this by turning it on with no clothes in and see if it will go into the spin cycle with no clothes in, if it does then chances are its not weighing the clothes properly and would end up costing a fortune to put right as it sounds like you spent a lot of money on parts all ready, so give i a try with no clothes in and see if it will spin, have you tried turning the drum by hand when its switched off to check for any grinding noises or jerking when you try to turn it by hand, im not sure how the balance sensor works or even where it is as its a new feature in the last few years but people are now starting to have problems with this feature and it stops the machine from spinning leaving the clothes soaking yet, so give it a try empty and see what happens
May 16, 2012 | Whirlpool Washing Machines
Whirlpool cabrio model WTW7340XWO ties cloths into a knot when spinning
You buy another top load high efficiency machine and load the clothes in same manner, you will get same result. No matter whether it is whirlpool or samsung or LG.
If you buy Maytag, Amana, KitchenAid, JennAir, Roper, Inglis and even sometime Kenmore. You will be buying the same Whirlpool Corporation machine with a different face plate.
hey listen your machine drum gone
Oct 09, 2017 | Whirlpool R 850 RT Washing Machines
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Dec 30, 2008 | Siemens WK61420GB Front Load Washer /...
Frigidaire ATF6000ES Front Load Washer Logo
59 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
