Question about Dell E173FP 17" LCD Flat Panel Monitor
Monitor display I had a hard drive crash recently, which resulted in my having to re-load all of my software. Since re-installation, my monitor is working, but when I drag a window, the window moves in what I would describe as "waves". It seems to "flow" across the screen instead of just moving across the screen. Does anyone know what I need to do to correct this?
  • 9,098 Answers
You might want to check the refresh rate in your advanced settings under display properites. Under Windows it shouls be something like: Start Button > Settings > Control Panel > Display Then click on the Settings tab, and on that screen click Advanced On that screen, click on the Adapter tab. At that point, make sure the adapter listed matches yours, and refresh rate should probably set to adapter default. Hope that helps.
Posted on May 19, 2007
I have the software, Fiery for 65 C-KM version 1.1, how do i install it
Installing Fiery software is notoriously tricky! Although they refer to a different Fiery model, the files in the following link will give you a good idea of what is involved :
MediaFire
..... particularly the software installation guide.
Hope you get it sorted.
Mar 24, 2014 | Konica Minolta bizhub Office Equipment &...
Lg monitor.no pic or sound blue light on.e2241v
Computer ?
Probably the monitor is fine , the computer had a hard drive crash resulting in the " blue screen of death " .
Hard drive and Windows need to be replaced..............
Aug 06, 2013 | LG " 21.5"" LED Monitor E2241V"
MSI P965 Pt Continually re-boots on start-up
You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
Dec 31, 2011 | MSI P965 Platinum Motherboard
2005 Dell Inspiron 6000, I need to reload the operating software, my hard drive crashed and I have a new hard drive I am going to install. How do I go about loading in the software??
If you have your windows disc, go into your bios. Make sure your disc drive is the FIRST BOOT DEVICE. Then restart your pc and it should load from the cd.
Mar 23, 2011 | Dell Inspiron 6000 Notebook
Hi, My hard drive recently crashed. Can you suggest a replacement? I have SP1203N now.
Hi
My hard drive also crashed and I installed a Samsung SP2514N 250 GB and I found it very good.
Give it a try.
Nov 11, 2009 | Samsung (SP1203N) 120 GB Hard Drive
Registry File Failure c0000218
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
Jun 25, 2009 | Sony VAIO VGN-N110G/W Notebook
AcerPower 1000 -- VERY slow loading
Your potential problem might be a virus. If you are having an updated anti-virus software and are running regular scans and found nothing, Then this might be the problem, while making the system get restored, the frequent problem is that, xp doesn't load the drivers which you installed for your system and it loads its own drives (which sometimes won't go with your devices). Try installing the drivers (especially display and motherboard drivers). If this doesn't work, I better suggest that you do a complete format of the system and install windows xp afresh.. Then there should be no problem. These're the possible solutions which i can infer from the details you've given..
Regards..
Mar 17, 2009 | AcerPower 1000 (AP1000EA380M) PC Desktop
Winxp with serv pak 3 crashes when installing konica minolta pagepro 1350w
It must be because the software is not compatible with SP3; I've seen this a few times already. Does the Dell have SP3 installed? If not, I dare say that is the issue.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Konica Minolta PagePro 1350W Laser Printer
Acer 5050 crash problem.
It is highly unlikely its a crash......two operating systems cannot....CANNOT crash similtaneously. Its impossible! unless the hard drive you run both on is faulty BUT you wouldnt get Windows to load. Not even for a bit....you say all lights will stay if they were lit up but they some how dont stay on.........I think thats what you mean.........then you say you checked again and there were rectangles that look like a book that stopped blinking yet the power lite stayed on....Im at a lost But I dont think its a crash......only software crash it might be a hardware pronlem....
Sep 12, 2007 | Acer Aspire 5050-3242 Notebook
MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
Dell E173FP 17" LCD Flat Panel Monitor Logo
57 people viewed this question
Alun Cox
