Question about Black & Decker Prestige APP X850 Iron
How to open for checking the problem X 850 iron black & decker
SOURCE: Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
Posted on Jun 16, 2007
SOURCE: Does anyone know how to
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Posted on Mar 07, 2009
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
romsky79
  • 822 Answers
SOURCE: Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Posted on Aug 19, 2009
SOURCE: iron saying "error"
my **** is to big for my girls friends ***** how do i get it in?
Posted on Sep 19, 2009
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Jan 01, 2013 | Black & Decker D2030 Iron
How to open the water tank in the black and decker iron ir1375sc
Regarding the Black & Decker Iron. You all talk about how to put water in the iron but none answer the question how to do that? What part do we remove or open to change or put in the water? Please answer this as soon as possible. This will also be on my Facebook to anyone there can you too help me?
Dec 24, 2012 | Irons
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
My Black and Decker Steav Xpress AS 685 will not heat properly.
Please call Black & Decker at 800-231-9786 and request to speak to a supervisor. If you tell them that you aren't going to purchase another Black & Decker product again following this issue, they will help you.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Aug 05, 2009 | Black & Decker Steam Xpress AS250 Iron...
The cord gets hot
You have a short somewhere in the cord. As this is a risk for fire, the Iron should either be taken for repair or replaced.
Aug 03, 2009 | Black & Decker Irons
Where can I obtain a users manual for the Black & Decker AS675 iron?
Please visit www.useandcaremanuals.com or call Black & Decker customer service at 800-231-9786 for the manual you need,
Please post a comment if you need additional assistance.
Jul 12, 2009 | Black & Decker AS675 Iron
Describe your Black & Decker
Please call Black & Decker customer service at 800-231-9786 so that we may determine your warranty status. Mon - Fri. 8:30 to 6:00 EST.
Jul 07, 2009 | Black & Decker AS150 Iron
Iron saying "error"
May 11, 2009 | Black & Decker D2030 Iron
Black & Decker Prestige APP X850 Iron Logo
18 people viewed this question
Top Black & Decker Irons Experts
tfelton3
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
