Question about HP Pavilion a1720n PC Desktop
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
I turn the computer on and the fan just runs. I receive no beeps and the monitor isn't receiving any signal from the computer. Nothing responds accept the fan at turn on. I turned off the computer, pulled out the CMOS battery for a few minutes, reset the boards to ensure they were seated correctly but still have the same issue. Any suggestions?
    Sergeant:
  • 378 Answers
Sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Posted on Feb 01, 2013
SOURCE: I have replaced 2x256 RAM
This problem occurs because of frequency incompatible between RAM.
For that you need to install same frequency RAM .
Also try with only 1 RAM make sure both RAM is working fine.
Try different RAM slot if 1slot or RAM is not working then also this problem occurs.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jan 06, 2011
Idahoodini
  • 82 Answers
SOURCE: PC was booting to HP screen with constant beep.
If the computer is not reaching the BIOS screen one of the components is most likely faulty. I strongly suspect that it is either the Motherboard or the CPU. If you have made sure the CPU is seated correctly you may need to try alternate motherboards or try the CPU in an alternate computer/Visa-Versa. Hope this helps you troubleshoot and good luck.
Posted on Mar 14, 2011
SOURCE: HP PAVILION SLIMLINE S3300N MY COMPUTER IS RUNNING
the fans should work since start for a while ...check the power supply if it has any connection to it or if it is connected from the motherboard...is a thing you should concern before you kill you motherboard or even worse the processor...
Posted on Jun 19, 2011
hunter19_46m
  • 7482 Answers
SOURCE: screen locked up, turned computer
Hi hay783...
Sounds like you may have a virus/trojan/worm/etc...
To remove a virus,trojan,worm,etc from your computer...do it the EASY way...let someone else do it for you.
Start your computer, as the computer is starting keep tapping the F8 Key.
This will start the computer in the Safe Mode.
Once in the safe mode go to the following webage below and download,install, and run Microsoft Safety Scanner for FREE.
Once you run the Microsoft Safety Scanner (it may take quite a while depending on the size of your hard drive) it will remove all the virus's,trojans,worms,etc it finds, if it does not completely remove them all you will be given a chance to chat with a Microsoft Professional thru a pop open window and he will take control of your computer (with your permission) and finish removing all the rest of the virus's, trojans, or worms that are on your computer for FREE!! Can't beat FREE!!
Please take time to rate me
Posted on Sep 05, 2011
  • 58 Answers
SOURCE: HP a6500f will not come on...no HP Logo...no beeps...black screen...fans run
if u have system mechanic, you can use the disc to boot from and it'll read your MBR....it is probably messed up....and needs to be repaired. Have you ever used a registry cleaner? if not, you also may have tons of registry errors....and registry errors can also give you blk screen of death.if you have no system mechnic disc nor can borrow one, then try this.....http://download.cnet.com/MbrFix/3000-2094_4-10485990.html?tag=mncol;1
please post back you findings
Posted on Apr 23, 2012
HP Pavilion dv6448se Notebook PC Won't Boot.
it restarts on booting screen or else at start up screen itself?
Jun 08, 2012 | HP Computers & Internet
Apr 22, 2012 | HP KQ495AA Pavilion A6500F Desktop PC
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 28, 2012 | Computers & Internet
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
My hp Pavilion dv6000 keeps restarting each time and the screen is left blank all the time. I don't hear any sounds either to detect any hw failure. It's reseting each 13-15 seconds after turning on so I'm...
dv6000, NO OS stated, whY? XP?
for now we get bios going first, damn the OS.
first take the old shorted main battery out,
run on AC only. run now? fan must blow first does it?
also the CCLF go dead, at 20k hours used. black screens for ever now. CCLF is dead LCD backlamps. but fan dead is other issue.
the COin cell goes bad now, ever replace that?
HP RTC coin cell battery , tiny, a $2 fix.
they dont last for 11 years, sorry.
power button dead?
fan dead,?
screen dead. (never ever shows text)???
hdd does not spin making normal noise?
cd eject button dead.?
no beeps?
no caps lock blink codes.?
the AC pack is dead if the PC is %100 dead on AC most times
I can show you 10 to 20 more things inside that can do that.
takes a full dismantle to fix some,
My guess a shop repair is not in the cards?
Jan 06, 2018 | HP Pavilion dv6000t Notebook
HP Pavilion dv6700. no screen.
Please run system restore to an earlier date.
Start system holding down f11 key till you hear a beep then follow the screen instructions.
Good luck.
Mar 21, 2010 | HP Pavilion DV6700T Notebook
Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
HP Pavilion a1720n PC Desktop Logo
238 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
