Question about Polaroid OneStep AutoFocus Instant Camera
Vivitar Instant Slide Printer
How do I insert the film pack into the Vivitar Printer? I opened the top and slide the film pack into place with the black paper facing upward. What and how do I get the film to the roller? I've never worked with pull apart film before. Thanks
I asked a friend who has used a Land camera how to insert the film.
Posted on Jan 05, 2009
I have a vivitar camera 3188 and can not find where to insert the battery can you help please?
The battery compartment is along the left edge of the camera on the side nearest the lens. You will see some ridges along that side. Place your thumb on the ridges and slide the cover up toward the top of the camera. Once it slides up about 1/4 inch it will open on a hinge.
Nov 05, 2014 | Vivitar ViviCam 3188 Digital Camera
I have not used this camera in years and assume that film battery is dead - green light flashes and also wondering if tab is not on the film - how do I get out. Is there a place other than film to put...
Polaroid 600 film cameras only have a single battery, built into the film packs. To remove the film pack, open the door on the door and grip the sides of the pack and slide it out.
Jul 06, 2011 | Polaroid One600 Pro Instant Camera
How do i load the film
There's a sliding catch on the left side of the camera (as viewed from the front) at the forward edge. Slide it and the lower front panel drops down to reveal the loading slot. Insert the photo pack (you may need to remove an old empty photo pack first).
If the new photo pack is an original Polaroid one, then because they are all so old and far out of date then you may find that the battery is totally dead or has just enough power to eject the cover slide and perhaps one photo. If that is the case either convert your camera to accept an external 6v dc power supply before using the expensive photo pack or buy a freshly manufactured compatible pack from The Impossible Project.
May 04, 2011 | Polaroid One600 Pro Instant Camera
Hi! I own a vivitar slide printer. It turns on but the shutter release button does not work. No audible click. Nothing! I tried the timer button and I started getting an annoying whistling sound I could...
Hi, I just got the vivitar too, and had the exact same issue.
The unit WILL NOT FIRE unless the slide is inserted along with the little removable "film holder" frame that comes with the vivitar. Hopefully you got this with your unit. There is some sort of thickness sensor in the slide slot, so both a slide and the holder (or something of similar thickness) to get the unit to work. Mine fires with no problem now. And I found that the "high pitched whistling" goes away if you let the printer sit turned on for a while, I think it's just the flash capacitor getting used to being charged. My unit has no noise anymore. Best of luck.
Dec 12, 2010 | Vivitar Cameras
I have purchased a used camera and I do not know what the dark slide is for. Do you pull it out before you take a picture? What is it for. Is it so you can remove the back with film in it? This is the...
After loading the back with film, the dark slide is inserted so you may remove the back without ecxposing the film. Suppose you had 2 different back, 1 with b&w and the other has color. You are shooting with color. Load the color film and before shooting, remove the dark slide. After a few shots, you decide to change to B&W, insert the dark slide, change backs, remove that dark slide and continue shooting. This is assuming that you have 2 dark slides, 1 for each back. If you only have 1 dark slide, then the back that is not on the camera needs it if it is loaded with film and the other back will have to stay on the camera.
Nov 01, 2010 | Mamiya 645 Pro TL Medium Format Camera
How do I open the camera up to check for batteries and film?
there should be a little slide door on the side of the camera or on the bottom slide it left or towards u and it should open.
Jan 19, 2010 | Polaroid One600 Pro Instant Camera
Polaroid Spectra 1200si
Check to see if the film is still good because if it is not the built in battery might have died. Check to make sure that the film was going in the correct way and that nothing was blockin the film pack from going in.
Jun 22, 2009 | Polaroid Spectra 1200si Instant Camera
Can't open vivitar 5388
Use the rewind knob to rewind the film. Once the film is rewound, lift the knob up and the back should open. Then you can remove the film cassette and insert a new cassette and load the film.
Jun 11, 2009 | Photography
Battery
The battery pack is built into the film cartridge. Every time you insert a new film pack, you get a fresh battery. Problem is, you are going to have a hard time finding Polaroid film, as they have ceased production of most of their instant film packs.
Apr 04, 2009 | Polaroid One600 Pro Instant Camera
First time i have scanned slides. not sure how to load them. do you slip them in from top, then cover with the vertical slide? i have put in a slide but can't read it--it comes out black when i try to scan...
double click the HP solution center open the scanner lid remove the TMA cover (transparent material adapter) by pulling the cover up place the slides onto the slide holder insert the slides w the top of the slides pointing up and the front of the slide facing you close the lid press the scan film in the HP dialog box select picture select scan positive, and select TMA click scan
goodluck
cheers
Dec 22, 2008 | HP Scanjet 4850
Polaroid OneStep AutoFocus Instant Camera Logo
420 people viewed this question
Top Polaroid Photography Experts
Myrddin R Emrys
Myrddin R Emrys
NOEL
NOEL
David Payne
David Payne
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
