Question about GE Profile Spectra JBP95 Electric Kitchen Range
GE model JB965S0D1SS won't heat fully
Display reads the correct temp however the oven does not fully heat up on the BAKE setting. It does however heat up completely on convection bake
3 Suggested Answers
  • 61 Answers
SOURCE: Electric range displays bake probe
if you need a parts check out appliance parts solutions
Posted on Feb 10, 2010
  • 193 Answers
SOURCE: No heat when selecting Convection Bake or Roast setting,
selector switch
element
thermostat
Posted on Apr 25, 2010
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Kenmorw built-in oven (Model #30129) won't maintain cooking temp, flame is off and on continously, take twice as long to bake or broil food. If the temp is set for 500, the oven temp might be 250.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Ovens
On "bake" my GE profile
make sure the display is correct put a thermometor in oven to get correct reading
Mar 18, 2011 | GE Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
JTP18WD01WW no broli, no bake panel works
my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
Nov 04, 2008 | GE Profile JTP18 Electric Single Oven
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Preheating
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jan 13, 2008 | GE Profile J2S968 Dual Fuel (Electric and...
GE Profile Spectra JBP95 Electric Kitchen Range Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
