My tv is flickering, after 5 minutes - Televison & Video
  • 673 Answers
Picture tube is a bit low, turn up the G2 that will help or a time and no its not worth replacing the tube,
Posted on Nov 02, 2012
Olevia VCF-42FDV1U Flickering Screen
test the IPM fail, cable connection. God bless you
see the diagram attached.
Jul 20, 2013 | Televison & Video
Repair tv
You didn't say anything about the model or make but a lot of times this comes from bad capacitors...try this...on the open fins on the back of the TV, try putting a blow comb on there and set it on low and leave it there for about 3 minutes, turn the set on and see if it comes right on, if it does there are bad caps on the power board, it could be replaced or you could repair it yourself for a couple dollars
Dec 17, 2017 | Zenith R56W36 56" Rear Projection...
Proscan tv flickering
I'm sorry that the picture on the TV has constant flickering. Please follow the troubleshooting steps and check the operation:
  • Please make sure that the connections are secure and proper.
  • Try connecting a different video source like DVD player or VCR and check the operation. If it works with another device, the issue might be with the input device currently.
  • Also try connecting the device to a different port in the TV if no other devices are available.
  • If the issue persists, try with a different cable.
  • Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
Thanks for understanding. Please let me know if you require any clarifications/additional help.
Oct 18, 2011 | Proscan 42LA45H 42 in. LCD TV
My Maxent mx-50x3 has a intermitten problem, when I turn it on, it does not have a picture, 5 minutes later it will flicker than a couple minutes more it has a picture while flickering, another ten minutes...
i had the similar problem. i'm not a tech but like to take stuff apart to find the problem. on my tv i took the back completely off. do not touch the boards. if you follow the power supply from the plug up two boards i found a small white adjustment screw. it was just up and to the right slightly from the plug. with a small screw driver i turned it slightly to the right and the flickering and delayed picture went away. couldn't tell you why it worked but it did. hope this helps, saved us $800 to buy a new tv.
Aug 20, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Screen has started to flicker constantly. tv is 9 months old. When switched off flickering stops for about 5-10 minutes and then starts again
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Feb 23, 2011 | Samsung LN55C650 TV
Flicker after warm up
Arcing noise suggests HV leak--get a tech to look at set!
Oct 03, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
