My 42 inch philips (42PFP5532D) has blank screen but blue light to show its on but nothing on screen :(
Model is 42PFP5532D. i plug the power in i get red light, press the standby button turns blue as if its on but still blank screen. how much would it cost to get fixed?
  • Royston Hocking Nov 04, 2012
    i have no idea how to check any of this, sorry. any other suggestions or advice? thank you
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Just let me know if their is a sound when you turn on the tv then the only problem is black screen. if you can get sound tried to press the channel up/down button let see if you can get a channel. if you hear that receive channel that was mean the problem is either the screen back light get busted or the power inverter is defective. hope this can help good luck.
Posted on Nov 03, 2012
  • 1 more comment
    i tired going through the sources blindly no joy unable to get sound. can the power inverter be fixed if defected? thank you
  • francoise cleofas
    francoise cleofas Nov 04, 2012
    yes it can be repaired but it will depend on the parts availability in the electronic store or through online. these are parts you are going to check weather the inverter board get bad. check if the high voltage transformer get shorted or get burned. then also if the transistor as will as ic their pins get shorted, you are going to have a component testing using with the digital or analog tester. however if you don't have an idea on how to check this parts, the better solution to check weather the inverter board get bad is to replaced the back light at least one side of the panel. since you can not get to check the inverter board only by checking the voltage because it has a high voltage output and can not test by a digital tester only.
    im not sure how to check for anything sorry, any diagramss or images of what im looking for? thank you
There is a kit you can buy on ebay for 12.99 or you can buy the power supply board for 89.00 and fix it yourself. very easy
Posted on May 20, 2013
jerryg50
  • 1689 Answers
SOURCE: Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Posted on Jun 03, 2008
  • 9 Answers
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
Posted on May 18, 2009
  • 61 Answers
SOURCE: TV freezes at "Philips" screen
a professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
Posted on Jun 01, 2009
jhinsincity
  • 616 Answers
SOURCE: Digistar PH-4210D Black Screen
Plasma tvs do not have "back lights" LCDs do. you probably have a bad driver board along with the upper or lower buffer board or maybe both, best to have a tv shop look at it.
Posted on Aug 30, 2009
SOURCE: My Polaroid 42 inch LCD Tv will not turn on. It
Polaroid's power supplies have been notorious in early models...suspect this is where your problem is. If you are out of warranty, the supply is usually located dead center in the back of the TV. Easy to get out, easy to put in...not sure of the money. Mine was a hundred bucks, but I bought it from a third party. Good luck.
Posted on Feb 07, 2010
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
Baird 42 inch LCD tv turns on but has black screen but no picture or sound
I have a 42 inch baird tv it will show the blue screen for a couple of seconds and then there's nothing just a black screen
Dec 08, 2010 | Televison & Video
Blue power light is on the tv cant turn it off
Unplug the TV wait 10 Seconds and Plug it back in. Should work fine
Sep 26, 2009 | RCA L42FHD37 42 in. LCD HDTV
Philips 42PFP5532D/ MAKES THE NORMAL CLICKING NOISE WHEN YOU TURN IT ON . BUT IT CLICKS BACK OF AGAIN SO YOU DONT EVEN GET A PICTURE ALL YOU GET IS THE RED STANDBYE LIGHT FLASHING DO YOU NO WHAT THE...
philips tv's test them selves when turned on if something is wrong it shuts down you need a tech to determine your problem more than likely it is you power supply
Sep 18, 2009 | Philips 42PFP5332D 42 in. Plasma...
Jun 01, 2009 | Philips 42PFL3603D 42 in. LCD TV
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
Aug 10, 2008 | Delphi NAV200 GPS Receiver
System won't power up
ITS BROKE - YOU HAVE TO GET IT FIXED OR THROW IT OUT. SAME THING HAPPENED TO US -UNDER WARRANTY BUT WE HAVE TO PAY THE $80 TO SHIP IT TO THEM. WHAT A FARSE.
Aug 04, 2008 | Olevia LT42HVi 42 in. LCD Television
Blank Screen
Many have replaced caps on the SMPS board, with success:
2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 100μF 25v
Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Once you get it on, there are adjustments to the VS voltage to cure the speckle.
Jul 12, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
423 people viewed this question
Top Televison & Video Experts
