Question about Refrigerators
Can any1 tell me why the divider between freezer n fridge is getting hot at front on my Samsung rs21dcns, and is it an easy fix? Thanks very much
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
The warm feeling around the doors is normal... they have either a very small heat element inside there, or the discharge line is routed through there, which is to preventcondensation from forming around the edges of the door. If it has an "energy saver" switch inside near the thermostat, turning this switch to the energy saver position turns off the heaters around the door edges, but may cause condensation to form if the humidity level inside the house is high.
Posted on Nov 03, 2012
dididsaythat
  • 291 Answers
SOURCE: samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Posted on Aug 21, 2007
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
Speed boy
  • 76 Answers
SOURCE: Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Posted on Sep 10, 2008
  • 1531 Answers
SOURCE: Divider between the fridge and freezer is hot to
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Posted on Jun 03, 2010
Macmarkus
  • 2605 Answers
SOURCE: the divider that seperates the freezer from the
Hi, Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Posted on Jul 31, 2010
How to fix a problem with hot dividing panel and sides of a Westinghouse WSE7000SA fridge freezer
It gets hot to defrost the fins on the freezer coils. You either have a bad timer or switch that tells the defroster to stop working.
Jan 28, 2015 | Westinghouse Refrigerators
Have a daewoo frs u20dcb side by side fridge an the centre post dividing fridge and freezer is getting very hot is this a problem
There is a fixed thermostat behind the panel in the freezer. It might be bad. Get a new thermostat fro your model refrigerator at an appliance parts store and replace it. Only two wires attach to it. It is an easy job.
Apr 29, 2014 | Refrigerators
Samsung rs21dcns side by side fridge....the temp on fridge keeps going up even when you change to lower ..can i fix this
if you can fit a new termostat in yourself it a yes!
if not then its still yes but the repair man will need to fit one for you
Oct 25, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung RS21DCNS Water dispenser freezing up
Sounds like you have the freezer temperature set too low.
Oct 09, 2009 | Refrigerators
Samsung RS21DCNS Fridge not getting cold
0845 726 7864 samsung know of this problem and are doing free fixes to all of them just phone the number it doesnt matter about the warranty as they have extended them all free to 5 yrs.
There are numerous problems including noisy fan that stops when doors open to no water and all are free to fix.
Hope this helps.
Sep 01, 2009 | Samsung RS2556 Side by Side Refrigerator
SAMSUNG RS21DCNS
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
Divider red hot
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side center divider front extremely hot
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
