Question about Denon Audio Players & Recorders
Denon DP- 60L Tonearm bearings are loose, How should I adjust them..?
The tonearm has alot of play, both up and down, and from left to right..
    Master:
  • 444 Answers
They can not be adjusted, Turn table has obvisily been abuse,Just buy a different one, End don,t abuse it,
Posted on Nov 02, 2012
Benimur
  • 6966 Answers
SOURCE: Technics sl-1200 tonearm problem
Hi, Assuming the the turntable is on a level platform and that you have "adjusted the weight and anti skating correctly", might it not be just the styli/cartridge that's left in question? Visually check the styli/cartridge assembly, look for unevenness of wear on the needle itself, compare with a known good styli the angle. On some rare instances, it is the shielded wire inside the arm. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 30, 2007
maklean
  • 1665 Answers
SOURCE: Denon DP52F tonearm tube is turning freely
You must raise top cover to have acces to arm support shaft and tighten holding nut.
Posted on Sep 14, 2008
djproaudio
  • 515 Answers
SOURCE: Numark TTX tonearm base repair
Unfortunately, the only way to access the tonearm is through the bottom. It's not that difficult, but you should be very careful when placing your turntable upside down to remove the base.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Posted on Nov 04, 2008
  • 42 Answers
SOURCE: i have a old DENON
Do you mean no sound, or practically no sound?
It is most likely that you will need to buy a phono preamp to connect the two.
Posted on Jan 24, 2009
  • 104 Answers
SOURCE: Turntable tonearm returns but starts playing record over again.
http://www.vinylengine.com/library/pioneer/pl-570.shtml
on page 8 of the above service manual for your model it shows 4 electrical switches that tell the computer what 'state' the mechanism is in at any given time. Either one or more of the switches are intermittant or the mechanism has dried up grease that is slowing down the operation and basically gumming up the works. the old grease would have to be removed and replaced when it is causing binding. The switch just to the right of where is says "microswitch ksf-023" is an 'open air' type and so would be the most likely suspect. it simply needs to be cleaned with a super fine file designed only for cleaning switch contacts. THIS SERVICE SHOULD ONLY BE PERFORMED BY QUALIFIED PERSONNEL ONLY!!!!!
Posted on Feb 11, 2009
Adjust tonearm
Hi, most auto turntables have a screw to adjust the landing position of the tonearm. It is normally at the tonearm base on the left side under a rubber grommet. Stylus city
Aug 01, 2014 | Audio Players & Recorders
Denon DP-7F subweights
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Nov 23, 2013 | Denon DP-47F Turntable
My Denon DP-26F tonearm does not return "all" the way when finished playing a record.
Tonearm can be adjusted to travel back to its support. At the base of the tonearm is a small rubber stopper. Remove the stopper and insert a flat blade screwdriver into the slot beneath. Turn to the left and then test arm for repositioning correct. Adjust until its correct. John
Dec 27, 2012 | Denon DP-26F Turntable
My denon 26-f turntable stylus arm lifts about 2 minutes before end of record. how can this be adjusted on the turntable?
Hi Richard, at the base of the tonearm look for a rubber grommet. Under it you will find a screw. Adjust clockwise slightly to make the tonearm lift further along. Fine tune antil sorted. If the adjustment is not at tonearm base remove the rubber platter mat. If the platter has an access hole in it rotate platter so the hole is near the tonearm and look for scew to adjust. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
Arm Looping
Generally speaking, needle should follow the groove, if following not present:
1. dust and grime built up in the groove that stops need to pass. you should be able to hear "click, click, click" each time needle comes to the same spot. - clean your record in details.
2. cartridge/arm bias and weight too light causing needle to skid over path. - adjust the effective bias and weight according to cartridge spec.
If problem persist, write me again.
pc-cook
Jan 25, 2008 | Technics SL-1200MK2 Turntable
Technics mk2 tone arm replacement
once you soldered to circuit board place - this might help Advanced Tonearm stuff Tightening the suspension on your tonearm Some TT's have tonearms which seem to be loose. If you grab the tonearm and pull it gently back and forth and it seems loose you can tighten it. It shouldn't move at all. A loose suspension can severely affect it's performance - from jumping needles to binding. It's pretty easy to tighten the suspension. You'll need a small flat screwdriver and a large one. Use the large one to loosen the outer locking screw on the top of the pivot point. Now use the smaller screwdriver to loosen up the smaller screw. Put a drop of oil where the bearings are (under that top support on the other end of the adjustment screw) so that it doesn't bind. Now tighten the small screw slowly until it just contacts the bearings. Adjust the tightness so the tonearm doesn't wiggle if you pull on it but leave it loose enough for the tonearm to pivot freely without binding. Adjust carefully and don't overtighten otherwise the bearings will be damaged! When done, tighten up the locking screw. Tightening up the headshell locking ring Have you put on your headshell, twisted that knurled tightener at the end of the tonearm as tight as possible and have found that the headshell still moves around? What will happen is that the headshell won't sit parallel to the record but may be tilted as a result of twisting of the headshell. This usually occurs when you change headshells a lot or if you've had your turntable for a while, and can contribute to needle jumping so here's what you do to fix it. First read 3.2 on base disassembly. Remove the rubber base. There will be this big piece of hard black plastic covering almost everything. You'll need to remove it. To remove the tonearm assembly look for three screws (all formerly under that black plastic) and unscrew them. Be careful not to drop the tonearm when you remove that last screw! Now, remove the tonearm assembly from the rest of the 1200, and look at the bottom of the tonearm where the headshell is put in. There will be two tiny philips screws there. Get a jewelers screwdriver of the CORRECT size and tighten those up. Put the headshell on and try wiggling it to make sure everything is right. Now put your tonearm back on and close everything back up. hope this helps peace DJ Nyce
Jun 14, 2007 | Technics SL-1200MK2 Turntable
300 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
