Question about Refrigerators
I have a sharp sj-51h-wh and all of a sudden its making this really constant and annoying sound, kind of like a vibrating noise any ideas
bmwrider
  • 215 Answers
SOURCE: noise
Does your radio have a knob or switch which is marked as "SQEULCH" If it's a knob just rotate it until the noise stops and then just add a little bit more. It sounds like the squelch is acting a bit slow after you let the transmit button go. If it's a switch I'm afraid it means a trip to a technician for adjustment. BMW
Posted on May 22, 2006
fridgetech
  • 473 Answers
SOURCE: ice-maker noise/vibration
That noise is coming from the icemaker motor module.  It is behind the the white square plastic cover which will pop off.  However it may be that the ice maker thermostat isn't opening and closing at the right time which would turn off the heater and put stress on the module to make it noisy.  Your best bet is to replace the whole ice maker for that is the easiest solution instead of buying parts which may add up to the cost a whole unit.  If you need help finding parts give me your entire model # from the sticker inside the fridge section.  You can look it up yourself at www3.sears.com to get the part #.  I have seen great "buy it now" prices on ebay.  If you don't think this solves your problem let me know before you rate the solution please.
Posted on Oct 13, 2007
SOURCE: Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Posted on Jan 10, 2008
SOURCE: annoying projector noise
Well here is a partial solution. Turn off Dynamic Iris and the noise will go away. Now could someone tell me how to fix the Dynamic Iris?
Posted on Jan 26, 2008
  • 1122 Answers
SOURCE: need two trays for sharp
go to sears .com,click on parts,put in your model number get your part,cross check the price at repair clinic .com-mike
Posted on Nov 11, 2008
Our sharp fridge/freezer model SJ-45F-WH ISNT GETTING COLD IN THE FRIDGE. THE FREEZER IS WORKING PERFECTLY.WE HAVE TURNED IT OFF FOR A FEW HOURS AND TURNED IT ON AGAIN. THAT WORKED LAST TIME.Not now.
If your freezer is full of food move everything about an inch away from the back wall. This should let the air flow better the fridge gets its cold air from the freezer. So you have to make sure your not blocking the vents.
Nov 03, 2016 | Sharp Refrigerators
I have a 2000 Honda Accord and as I accelerate over 45 mph the care starts making a progressively louder humming/buzzing sound. When I turn slightly to the right the noise will go away. Any ideas wh
sounds like the wheels are out of balance, is there a slight vibration through the steering wheel at this speed? and does the problem stop if you go faster (please drive carefully)
Jan 24, 2012 | 2000 Honda Accord
After compressor on,Sears/Kenmore ac makes a loud vibration noise
sounds like head pressure problem it is most likely clogged on condenser try washing out really good then try again
Sep 10, 2009 | Heating & Cooling
Loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Jul 09, 2009 | Televison & Video
Compressor makes noise and goes on and off constantly
That foam block is an anti vibration dampening device. My guess is is goes up against the underneith od that compressor. The real problem is with the short cycling compressor. I would return that piece of junk.
Jun 30, 2009 | Heating & Cooling
Ford 1988 escort GL-Front wheel constant scrape-scrape,vibration
sounds like you need new brake pads and the rotors atleast turned down if not replaced
the pads should stop the noise and the rotors should stop the vibration/wobble
thanks wes
ps please rate me
Mar 27, 2009 | 1988 Ford Escort EXP
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
