Remote is unresponsive to tv and lcd light remains on
Have changed batteries in remote to normal (not rechargable) but light still remains on and tv is unresponsive to remote.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If it works from very close range the receiver is the issue.
Remote is unresponsive to tv and lcd light remains - 11_3_2012_12_07_18_am.jpg
Posted on Nov 03, 2012
  • 19 Answers
SOURCE: LG LCD flat screen TV - 42LG50-remote control is unresponsive
Sounds like a probable main board issue
Posted on Feb 21, 2009
SOURCE: Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Posted on Aug 01, 2009
SOURCE: can't turn tv on with remote, only manually, when on volume is at 100 and cannot be adjusted with remote or manually. channels cannot be changed with remote or manually. Changed batteries in remote,
replace with new batteries and it works --- so simple
Posted on Sep 22, 2009
roety
  • 585 Answers
SOURCE: my samsung 330 lcd-tv wont turn on. the red power
Hi my name is Roety,
I can help you with your issue ,
Most common issue is the power supply capacitors, check and replace any that look swollen like this
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Oct 28, 2009
SOURCE: Need code for remote. New remote needs replacing.
Cable and Satellite content providers control the remote codes,
and we apologize for any confusion during the remote programming.
Please try the following codes 10019, 0178, 10178, 0030, 10030,
0835, 10835, or for Dish Network try 627, 659 or 505. For Fios
TV (Verizon), try the code 3264. These codes may not work on some
universal remotes. If there is another code listed for Element
Electronics in your universal remote control guide, please try that
code. Refer to the Remote Control Guide under your TV’s model
number for more information.
Posted on Apr 06, 2010
Turns on white i can hear the audio and change through the cable channels with my comcast remote.The vizio remote will turn the tv on & off but none of the other buttons work and the screen remain
tcon board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Nov 19, 2017 | Vizio VOJ370F 37 in. LCD TV
Indication Light On, Black Screen, Unresponsive
I happened the same problem and the solution must change the power pack
Jan 25, 2014 | LG M2362D 23 in. LCD TV
My remote does not control the TV. It is in the cradle to charge and when I remove it I get a message that says, "Battery level low Place remote in recharging stand to charge battery". The...
Seems the battery in the remote is shot. Could even be a lose wire inside of it as well. May need to replace remote or dare ti take it apart and see if all wires are hooked up properly
Oct 27, 2017 | Logitech Harmony 890 LCD Remote Control
How to disable the light on the remote itself need to change the battery's every month
There is no way to turn off the light on the remote control. The light works as an infra red beam that relays messages to the television or any device it operates. I will advice you take out the battery once you are not operating the unit or you can get some rechargeable batteries that can be charged once the batteries are running down easily. You can get 4. So while you are using 2, you will be able to charge the remaining 2, while it is not in use.
I hope this information helped you.
Take care and good luck
Jan 05, 2011 | Samsung Ak59-00104k Remote Control
Remote control rmt b101a stopped working, changed batteries, same thing; did reset by pressing power, TV i/o and vol- simultaneously, still not working. Help!
Make sure that the Remote is operating in a range of 3 to 10 feet away from the unit.
Point the Remote directly towards the Remote Sensor of the Device.
Remove any obstacles that may be in the path of Remote and the Sensor.
Make sure that no interference is blocking the Remote to operate normally. Do not expose directly to Sunlight, bright florescent lights etc.
Try resetting the Remote by removing the batteries from the Remote control, press every button twice, and then re-install the batteries after 1 minute.
Make sure that none of the buttons on the Remote control is jammed.
Install fresh alkaline batteries in the Remote, do not use rechargeable batteries.
Make sure that the batteries are inserted by matching the polarity (+ & -).
Try resetting the Blu-ray Disc Player with which you're using the Remote.
If the issue persists, after all the possible troubleshooting steps, service may be required.
Thanks for using FixYa
Dec 03, 2010 | Sony RMT-B101A Remote Control
TV will not come on via the remote control and remains in standby
Try switching it off at the main switch on the TV. Then switch it back on from the same main switch on the TV. If the TV then comes on & works normally, then check the batteries in your remote control, they may need replacing.
Mar 28, 2009 | Samsung LE32A41B 32 in. HD-Ready LCD...
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
