Digitrex tv grey screen
I have a Digitrex CFD2271HAA and recently the reception became very bad and I worked out that that there was a problem with the tuner (tested other flat screens and they had no problem from that aerial point). I sourced and replaced the MAIN AV BOARD which includes a new tuner. When I turn on the TV I get a grey screen and no response to the remote other than the standby button. Help please
  • Alan Adams Nov 04, 2012
    Hi, Thanks for all the tips. Having looked at all and checked all connections, I have replaced the original main board and am back to the original problem. So, I believe the replacement board is faulty and am going to change it.
SOURCE: protron flat 32' tv with broke screen need to replace
The screen to my protron 32" broke can this be replaced
Posted on Jun 23, 2008
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
SOURCE: New 32 in flat screen Vizio tv will not turn on no
I had the same tv, same problem. take the back cover off and look for the 250v ceramic fuse (looks like a glass tube type, but is porcelin) For ease of replacement and a cost of about $00.80. I would start there. If that does not take care of it, than you can move on to the other options.
Posted on Jun 25, 2009
SOURCE: akira tv 21 slim pure flat CT-21 CSL 5AT-TT ,SCREEN LUCKED
saya punya tv 21akira slim kadang hidup-mati semua tegangan drop tapi kadang bisa hidup normal
Posted on Aug 05, 2009
  • 1632 Answers
SOURCE: New Samsung LCD TV won't turn on or off
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
My sony LEd Tv kdl-55ex720 has the vertical grey band stay in the middle of the screen
try to play a DVD to test if the problem is on TV or the digital or analog reception..
Jun 18, 2012 | Sony Televison & Video
Cant get the sky remote to work my digitrex tv
Hi
It's probably to do with your Sky remote control version (if it's an old remote it won't work new TV's). If you remove the battery cover and take a look inside the battery compartment area, you will see the version number somewhere on a sticker (if not then you probably have the older type of remote). You can also tell by the remote colour, if it's blue it's probably old and grey newer.
Hope this helps.
HillElectronix
Aug 04, 2011 | Televison & Video
Code to enable sky remote with Digitrex TV
I have a digitrex tv with remote indicating on reverse serial numbers( CTF2685. CTF3271. CTF4071) which I couldn't turn the volume up or down change the channel etc but this worked for me 1.press the tv button
2. Press select and the red button at the same time for 2 seconds the light will blink twice.
3. enter code 2193 and the light will blink twice. Problem was then solved sky remote fully functional hope this helps people out sure helped me thanks guys
Mar 08, 2010 | Televison & Video
Acer Aspire One, Screen turns strip-y grey/white
hi there, my sisters dell laptop does the same thing. My best guess is that a hard knock on the graphics card and knocked a few pins out of it. This is something that a average person can not do. My suggestion is to bring it to a computer shop and tell them that you think it's the monitor connections.
Jan 31, 2010 | Acer Aspire One PC Notebook
Problem on the main display screen on my Nokia 6085
Sounds like a bad lcd flex cable, i fixed mine by ordering the part from an international parts carrier, but if you are not technically inclined to open up your phone and possibly destroy it, i would not recommend it.
Oct 02, 2009 | Nokia 6085 Cellular Phone
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
Samsung flat screen tv 1 y.o. getting no picture just grey....t.v. says no input device "air 34" I have comcast cable. The other two tv's are getting perfect reception. I fell asleep with the tv on "sleep"...
Try to set up channel SEARCH again, this lets some tv`s find the cable channels and lock them in to the available one, also make sure the reception mode is on cable, "air 34" could be an antenna connection mode.
Feb 01, 2009 | Televison & Video
Digital Reciever Issues
I have the exact same problem.Check this out. http://www.fixya.com/support/t209330-lg_dat_250 Unfortunaley, for temporary use of other channels other than abc & abc2, you need to pull out the antenna lead when it is trying to program those stations back in. My serial number starts with 601, does yours?
Sep 30, 2007 | LG LH-D6230 System
Sanyo Flat Screen (DS27910) "Grey" Screen
dont know for sure but i think that the tube is going bad. Have one in my shop doing almost the same thing.Taped on the tube and it does strange things. My tube tester wont test this kind of tube that is in these sets.Not much help but it is a start.
Sep 17, 2006 | Sanyo DS27910 27" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
