Question about Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump...
Aqualux whirlpool tub how do I clean jets?
Jet coming from 1 outlet is less that others.
  • 652 Answers
Try and blow the lines out with air, sounds like something is stuffing the water jet. Drain system and turn off power first.
Posted on Feb 15, 2016
snap101
  • 117 Answers
SOURCE: can you cap off the jets of a whirlpool tub if you
you can but it's not worth the trouble of doing it! lots of fiberglass and you need to have access to the whole tub on the sides
Posted on Jul 29, 2009
smokenic
  • 49 Answers
SOURCE: jet tub just wont start
well i''m a plumber and it wouldn't be one of our problems. most likely, the electrishians didn't hook power up to it, or they did it wrong and burn't it out.
Posted on Sep 19, 2009
  • 80 Answers
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Posted on Sep 28, 2009
uspartscente
  • 717 Answers
SOURCE: RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
Posted on Sep 06, 2010
  • 1311 Answers
SOURCE: I have a Jacuzzi brand
The gasket around the jet may be leaking because it is deteriorating or the flange nut on the outer side of the jet has loosened up. Check all jets for loose hardware.
Posted on Sep 12, 2010
My Aqualux tub is not working correctly. When I push the button for the jets to start they do but when I let go of the button the jets stop, the button will not stay in place for the jets to work
Hello Sheri Walker
Not finding a lot of answers in the USA... (sorry)...
The really good news is the air parts of these
switches are terribly easy to test.. Could just be a loose nut on the tubing...
16A On Off Push Button Switch Jetted Whirlpool Jet For Bath Tub Spa...
For "spares" CONTACT
Fetim Group United Kingdom
PO Box 16847,
Solihull,
B90 9JE
United Kingdom
Email: enquiries@uk.fetimgroup.comTel: 0121 395 2000
Carnac the Magnificent
Jun 15, 2017 | Home
How do I fix a jet that isn't hardly pumping on my Aqualux jet tub? The other 8 jets work but no more bubbles. Is it the switch? Is that one jet clogged? Do I need a new pump? How do I get the jet out
hello Tami!
That particular jet is probably clogged.
You can find special cleaners NON ABRASIVE at your local hardware stores.
Be sure to tell them what cleaners you are looking for to make sure it is a non-abrasive type.
Or call in for service. Here is a link that may be helpful to you.
Best of Luck,
JP
Bacteria Alert How To Easily Clean Jacuzzi Bathtub Or Whirlpool Tub Hot...
Oct 28, 2015 | Home
On ultra jet 3 there is a 3 prong outlet below the seat on the right & has cord that goes to normal outlet is that how to charge it
Jet 3 Ultra www.pridemobility.com 33
VI. BATTERIES AND CHARGING
To charge the batteries using the off-board charger:
1. Position the front of your power chair next to a standard
electrical outlet.
2. Be certain the controller power is turned off and the
freewheel levers are in the engaged position. See III.
"Your Power Chair."
3. Plug the off-board charger into the off-board charger/
programming socket on the controller.
See figure 25.
4. Plug the off-board charger into the electrical outlet
You should use the charger supplied with the power chair. It is
the safest, most efficient tool to charge the batter-ies. We do not recommend using other types of
chargers (e.g., an automotive battery charger).
Sep 07, 2014 | Health & Beauty
Get jets unplugged
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Jan 19, 2014 | Whirlpool Home
My Royal bath tub leaves residue each time I use it. How can I stop this
US Parts Center
Oct 18, 2013 | Whirlpool 5"x36" White Bathroom Drop-in ...
I have a utilitech jet pump can only set pressure to 20-40 would like to set to at least 30-50 but cannot .The pump is less than 6 months old .any ideas other than i bought the wrong brand
Sorry Richard,
Sounds like you are correct, you bought the wrong type of pump...if your looking for pressure/output you might consider purchasing a "sprinkler pump"...they will go past 70psi and more
Please take time to rate me
Bud
Mar 31, 2013 | Utilitech 1-HP Cast Iron Shallow Well Jet...
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
Window washing fluid pump isn't working. Hums and runs, but no fluid comes out. Any ideas?
1. the washer fluid jets are plugged possibly and will not allow fluid to discharge. Take a small wire or needle and stick into the jet end where the fluid comes out and it should spray after that if that is the issue.
2. the lines coming from the washer pump could be broken or cut open. Remove the line at the back of the spray jet either at the hood or at the wiper arm, then attempt to spray the wiper fluid. If it does not spray then there is an open/broken line coming from the washer pump or the pump may have a problem. If fluid is coming out of the line, the jet again is plugged up. Also check to see that fluid is going into the washer pump (locating the pump and getting to it is sometimes not so easy depending on where the mfg put the pump).
Jan 18, 2013 | 1986 Buick Century
Turn saw on and in less than 2-3 seconds circuit breaker trips
Probably a weak breaker in your fuse panel try different outlet
Nov 12, 2012 | Jet 708662PK/JTAS - 10XL30 - 1 with 30...
Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Logo
349 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
