Question about Toshiba Televison & Video
I have a Toshiba DLP Projection Television 46HM95 and one of the fans stays on all the time can't find any data on the televison
Toshiba 46HM95 DLP Projection Televison One of the fans doesn't shut off isn't the bulb fan..
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
The fan on the digital board is MEANT to run 7/24 as that board is powered and up all the time, that is normal.
Posted on Nov 02, 2012
Testimonial: "Yes it explains everything thank you .."
  • 65 Answers
SOURCE: Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Posted on Dec 09, 2006
SOURCE: Television Problem
I have just run into the same thing, prior to the picture not coming on there was a loud whining noise, I thought it was the fan in the back, but, what I tried was removing the lower back panel, LIGHTLY tapping the light wheel assembly just left of the Bulb housing, and using a shop vac to first, **** the assembly around the edges and then reversing the air and Blowing it out. After much dust and dirt flying around the TV came on. It now only makes a little noise now and then, but, I will try this again today and then put the back panel back on. Since it would probably cost as much as a new TV for the color wheel, I gave this a try. For now, it is working.
Mr. Wizard
Posted on Jul 21, 2008
SOURCE: Humming noise in Toshiba television
my 46HM95 was humming also, I have the extended warranty and the company came out and diagnosed it as the light engine. the part was backordered and it was just fixed today, it was ordered back in February. Problem was solved.
Posted on Aug 25, 2008
ladywinn
  • 5138 Answers
SOURCE: toshiba 52" HM95 DLP green and red LED Blink>
If Fan behind Lamp is not running lamp will not come on,also CK blaster board.
Posted on Aug 09, 2009
  • 4234 Answers
SOURCE: Toshiba 43HX71 projection TV Convergence problem
Since the set seems to correct itself when "cool", I would first try resoldering the convergence IC area. Quite often, the convergence problems start with poor connections that eventually cause the ICs to fail. Rather than spending money on a repair kit, try the resoldering first. I will verify the kit contents in the meantime.
Please keep us posted on your progress.
Dan
Posted on Oct 02, 2009
Testimonial: "Yes, this was helpful"
Model 52hm95 DLP. Why won't it turn on?
http://www.manualslib.com/manual/180510/Toshiba-46hm95.html#product-52HM95
Jan 22, 2016 | Toshiba Televison & Video
57in Toshiba projection tv flicker all the time,what the problem?
Toshiba 56HM195 DLP Flickering Problem - YouTube
? 0:08
www.youtube.com/watch?v=SxnUYXkaLr4
Nov 21, 2009 - Uploaded by Brian Baute
Flickering & green boxes appearing all over my Toshiba56HM195 screen. This behavior is consistent all the time, with multiple lamps, and across multiple inp... ... Up next. Stay Away From Toshiba DLP Projection Television!
Oct 29, 2015 | Toshiba Televison & Video
Where are toshiba dlp 62hm95 fuses
I looked at the power board online and I do not see any glass fuses.
I only saw the pico fuses which you unsolder and resolder.
Here's an image of the power board: http://tvpartsandmore.com/wp-content/uploads/imported/46HM95-TOSHIBA-23764257-POWER-SUPPLY-UNIT-46HM95-52HM95-62HM15A-62HM95-62HMX95-191208846050.jpg
What is the problem with this TV?
www.aaatvservice.com
Aug 15, 2014 | Toshiba 62HM95 62" DLP HDTV
TOSHIBA dlp projection, model 42hm66 won't stay on
Could be the power supply. You can check the power from supply with multi-tester or voltmeter. If have a service manual, then I suggest testing the ballast as well
Aug 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
Toshiba DLP is it even worth it!
Ebay carries this lamp for about $160. Tech prices are falling fast, you can get a similar sized lcd or plasma for around $900 brand new at sams or costco.
May 14, 2009 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95
your lamp is out, if you buy one it comes with instructions on how to change it, it will take about 3 nin's
Jan 07, 2009 | Toshiba 46HM95 46" HDTV
Aug 12, 2008 | Toshiba 46HM95 46" HDTV
Toshiba dlp
The light engine part number is 234054 and cost $456.00
Dec 20, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
206 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
