Question about Makita 6337DWDE Cordless Drill
The clutch slips. I want to disable it so the drill works without the torgue feature.
I would rather not spend $50 on a new gear assembly on this old drill.
2 Suggested Answers
jj505
  • 195 Answers
SOURCE: clutch slipping on cordless drill. need spare parts to repair.
Are you sure you do not have a tourque adjustment problem. If not I do not believe Makita will want to send you parts,you would have to know what is precisely wrong and by the time you went back and forth you might as well find nearest dealer for repairs and google search Makita.com for service parts near you + zip code to get your drill fixed.
Thanks , Please rate jj505
Posted on Mar 29, 2009
Yamaha royal star motorcycle cluch whine and shudder in 4th and 5th gear at any speed
It is slipping. These big yamahas normally have slipping clutches. Mine slips, I've just learned to baby the clutch. Make sure you are in the most comfortable gear for the speed you are running at. Avoid rolling on full power at low speeds in higher gears. It's the nature of these great beasts. Clutch springs are too weak in these bikes, you may consider an aftermarket clutch spring assembly. The "shudder"(intermittent slipping) is caused by glazing. Make sure you are using the right lubricants for your bike, some synthetics can cause problems.
1)Adjust clutch cable correctly, check
2)Pull the clutch assembly apart, if there is little wear then you have "glazed" plates, clean each plate with 600 grit sandpaper and reassemble...get a new clutch spring assembly (weakened spring causes "shudder", slippage, and consequently glazing). Reassemble and adjust correctly (many forums out there with info).
3)Replace the full assembly and adjust correctly at setup. Adjust regularly....I check adjustment about every 300-500 miles.
4)Pay a shop to do these things for you.
Oct 06, 2014 | 2005 Yamaha Royal Star Venture
2004 Celica clutch is slipping after car is underway .Say you are going 30 and accelerate the clutch will slip
It sounds like your clutch plate has worn away so slips when under pressure ie,pulling up hill or a heavy right foot.An easy way to test this is to pull your hand break on and try to pull away,if your revs lift without pulling the car then its slipping, there are clutch kits out there for around 50-70,they come with a new clutch plate,new bearing and a new preasure plate.If you do the job yourself make certain that no oily hands or grease gets anywher near the new clutch plate as i found out to my expence.It slipped as the old 1 did so had to do the job twice.Good luck and hope this helps.
Sep 17, 2013 | 2004 Toyota Celica
Gears slipping
Many of these have a torque clutch that is used in screwdriver mode that will slip when a certain torque is reached as set by the ring around the chuck area. If you want it to not slip, usually you set it on a symbol that looks like a twist drill.
Feb 01, 2012 | Hitachi DS18DFL 18V 1.5Ah Lithium Ion...
I HAVE A DEWALT 991 3/8 DRILL DRIVER. THE MOTOR TURNS AND SOUNDS FINE--THE CHUCK CAN BE HELD WITH LITTLE PRESSURE AND A CLICKING SOUNDS COMES FROM IT. DO YOU THINK IT COULD BE THE CLUTCH ASSEMBLY? JIM
Ensure the clutch collar is turned to where the little drill bit Icon is top dead center of the drill. If this is so, and your gear selector switch is not between gears, you will need a clutch. If this is a 991 Type 1, you may be able to get away with just an output gear, which rides against the ball bearings of the clutch.
392755-00 Output Gear part #. Generally when it is that bad, you will have to remove the clutch from the transmission without taking off the chuck, because the needed resistance for that operation is simply not available.
Nov 11, 2010 | Dewalt 18 Volt Compact Drill Kit
14.4 MXT grinding under pressure
there is a collar inside the clutch assemble that probably has the top of the teeth worn off. Unless you find a service center that has saved some good ones you probably will have to replace the whole clutch assembly.
Sep 27, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Why does the hatachi ds14 dmr slip
Mine is slipping in one of the ratios because the plastic molded teeth in the gear housing have stripped out. The chuck still turns but no matter how tight the clutch is it still slips because the whole gear assembly is spinning in the housing. The part is No. 18 on the exploded parts diagram and is relatively cheap to buy if you want to fix it yourself. Also the gear selector switch may have a build up in the slot in the casing that stops it clicking into position. Good luck.
Jul 13, 2009 | Hitachi DS14DMR 14.4V 1/2" Driver Drill
When in drill mode the tork still kicks in on my dewalt
clutch is bad. can be repaired but ive always had a pro do it. bit spendy
Apr 22, 2009 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
1997 Audi A4 Transmission problem
front clutch needs renewing
Jan 10, 2009 | 2006 Audi A4
When drilling the clutch starts to slip
if it slips to easily that is a problem, but it is designed to slip some when the bit binds up in the concrete. If you feel it is too easy, I would not recommend trying to service at home. I used to work on them and they are a pain, the clutch is an assembly and I would recommend taking to an authorized service station so they can check the static slip on the clutch mechanism and then advise whether needs serviced or acceptable.
Sep 28, 2008 | Milwaukee 5321-21 Rotary Hammer
Makita 6337DWDE Cordless Drill Logo
22 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
