Question about Sony KDL 40CX520 40 CX520 Series Full HD BRAVIA Multi System LCD TV
My sony bravia kdl-40cx520 has a broken screen and seems to have ink inside of the screen what can you do to fix this and what will the cost be roughly?
Has been kicked in the middle of the screen and cause the lcds to leak ink my guess but im not the expert
    Top Expert:
  • Sony Master
  • 14,553 Answers
If the screen is damaged or destroyed in any sense of the word, cheaper to buy a new set as part cost alone will exceed cost of new set.
Posted on Nov 02, 2012
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
SOURCE: 12 little horizontal lines in Sony Bravia KDL-52W4100
we have the same exact tv and it is not even a year old. we are told that it is the display panel and it is a well known problem with this tv. we were also told that there is a shortage of these parts. they had 283 on order, but only received 35. you need to call sony and tell them that you have this problem. they should warranty this for you even if your tv is 3 months past the warranty period. since this is a well known problem with this tv, keep on them.
Posted on Nov 24, 2009
Testimonial: "It in fact was a part of the lcd panel...the t-con board. I was able to research it and bought a box of parts off of a tv like mine and fixed it. Ron"
  • 148 Answers
SOURCE: 2 years old Sony Bravia KDL-52W3000 flat screen- I
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..Here is a picture of what you are looking for inside the tv...I hope this helped, if it did (or not)please rate, thank you!9441f5a.jpg
Posted on Feb 03, 2010
SOURCE: the picture has a shadow
you're LCD panel is gone. To replace it...$1500-$2K. But there is a silver lining to this dark cloud. No pun intended. Sony has posted on the US and Canadian site they will repair the XBR4 at no cost! i have the link right here. http://www.sony.ca/view/882.htm Canadian. http://esupport.sony.com/US/perl/news-item.pl?news_id=378&mdl=KDL46XBR4 USA.
It claims its the 46" but it appears to be a 40-52" problem. If you have an extended warranty it will pay for it.
Posted on Apr 06, 2010
How to stop sony demo mode
  • Turn on your Sony Braviaicon1.png.
  • Press and hold the Up Arrow button on the remote control
  • Press the Powerlb_icon1.png button on the TV while still holding down the Up Arrow button. The TV will turn off and then turn itself back on.
  • Release the Up Arrow button. Once the TV turns itself back on, it will restore your Sony Bravia to its factory settings.
  • http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html
    May 17, 2013 | Sony KDL 40CX520 40 CX520 Series Full HD...
    No sound no picture
    Check and replace its main power regulator board.
    Mar 31, 2013 | Sony KDL 40CX520 40 CX520 Series Full HD...
    I have a Sony Bravia KDL-40s5100 and the screen is now red and dark and seems to be in almost slow motion. My warranty is up by 28 days and Sony will not honor the repair and told me it was my cost. From...
    This problem can be caused by bad connections on the LVDS cable (the signal cable from the main pcb to the display control pcb.), sometimes cleaning the control pcb socket/cable plug can cure this. Other possibilities are: the display control PCB, or more probably, the display itself.
    Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
    We need our Sony 52W4100 Bravia screen replaced. What is the cost?
    Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV
    Part # 1-802-791-12, cost approx $2,251.54 + core
    Parts reference: Andrews electronics, 800 289 0300.
    May 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
    The Screen is broken for a Sony BRAVIA KDL-40S2000 40 in. HDTV LCD Television wich is the part number
    best bet would be to sell thinde tv as parts on ebay or something. Finding the screen would take a while and it would cost anywhere between $500 to $800. Might as well buy a new tv.
    Nov 17, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
    Help me
    Do you own a bank? You might need to
    Aug 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
    Sony Bravia LCD tv screen is broken
    i have the same set and the screen is cracked on it, i checked and the screen is $1050.00 so i believe its not worth fixing
    Jul 22, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
    Sony KDL 40CX520 40 CX520 Series Full HD BRAVIA Multi System LCD TV Logo
    354 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
