Question about Ricoh Aficio 2027 All-In-One Laser Printer
I need the IP address for a Ricoh aficio 2027
sir fixalot
  • 146 Answers
SOURCE: ricoh 2027 sc792 erorr code
This seems to be a finisher communication error. If you unit has a finisher on it check the connector.
Posted on May 26, 2008
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
Joed911
  • 4338 Answers
SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2008
  • 393 Answers
SOURCE: On Ricoh Aficio 2027 say error SC 873, the machine print by her self
Needs to delete e-mail data in the hard drive sp5-832-008 Enter service mode and run this sp mode
Posted on Jun 18, 2009
SOURCE: RICOH AFICIO 2027 SC392 CODE,IM AN ENGINEER AND
• Someone forgot to remove the toner
seal of the PCU
• ID sensor defective
• TD sensor abnormal
• Drum does not turn
• Development roller does not turn
• Poor connection of the PCU drum unit
Clean connector of TD sensor and
Try Change the development unit, adjust TD sensor.
Clean and you verify the connector of PCU.
Good luck...
Posted on Oct 21, 2009
How can i fix my aficio 2027 w/ loading toner error
Not loading toner is usually due to worn out dev gears in the PCU. Call your nearest Ricoh agent for a service call. A technician must come and fit new dev gears. Or the toner hopper is dirty and needs cleaning.
Jun 17, 2014 | Ricoh Aficio 2027 All-In-One Laser Printer
I fix the ip adress, sub-net mask and gateway adress already but it still can't print ands coming out check the following item and (103).my printer is ricoh aficio 2027
From what you say i think you have an IP conflict.
Unplug your machine and ping that IP address to see if you have response.
If you have a response it is because you already have this IP configured in other equipment.
You can also make shore if the network card of the machine is working. Plug a cable directly to the machine and see the result.
If you have any more doubt reply to me or post a new question.
See you
Apr 28, 2011 | Ricoh Aficio 2027 Black and White Copier
Change ip address at ricoh aficio 2022
Hi, to change the IP address of a Ricoh Aficio 2022, follow these steps:
- Press the User Tools/Counter button.
- Choose System Settings.
- Choose Interface Settings.
- Choose Network.
- Choose IP Address.
- To specify an IP address, choose Specify, and then enter the address you want to use. To have DHCP automatically assign an IP address, choose Auto-Obtain (DHCP).
- Exit out of the User Tools screen.
Dec 15, 2010 | Ricoh Aficio 2022 Black and White Copier
THE PRINTER IS ALREADY CONNECTED TO ONE COMPUTER HOW DO i CONNECT IT TO ANOTHER Configuring network Printing for Ricoh aFICIO 2027
Option 1) Right click on the printer on the PC that it's connected to, choose share, give it a name etc.
On the PC that its NOT connected to (the other PC now), go to start, run, type the name of the other pc and then two backslashes, ( otherpc\\ ) hit enter, you will then see a window in which the printer will be displayed, right click on it and choose connect, it may take a while and possibly will prompt a security warning (accept it) - then the printer will be in the printers menu for both computers.
With this method the PC that the printer is physically connected to will need to be turned on for the other PC to be able to print.
Option 2) - does the printer have an input for network? (rj45 plug) - if so then put a lan cable into it and go through the steps in the printer menu to get it an IP address. , then add the printer on each computer by going to add printer and putting in its IP address.
This method is a bit trickier and I've really just skimmed over it - let me know if you want more details on anything.
Also with this method it helps to give the printer a static IP address in your router so that it wont change with dhcp - like I said its a bit trickier so if method 1 is ok for you then use that, or you can ask me for any more info on anything.
Oct 29, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Oct 07, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh aficio 2027
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
User Manual
hi
u can download manuals from the below link
PDF file
http://www.ricoh-usa.com/downloads/manuals/bw/aficio2022-27.pdf
Jun 18, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
RICOH 2027 SC792 ERORR CODE
May 26, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh Aficio 2027 All-In-One Laser Printer Logo
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
