Question about Refrigerators
Water tray settings for samsung srs615dp? We recently purchased a Samsung srs615dp second hand abd have connected the water filter and installed with pressure valve as per instruction, I am just insure if the water tray settings it tells me to enter... Any info would be great :)
SOURCE: Water does not dispense from the door but there is water to the filter fitting
connect the water line in to the solenoid [with out the filter] to see if u dispensing water
Posted on Dec 01, 2007
gaeb7
  • 25 Answers
SOURCE: water not entering freezing tray on frigidare side
Try replacing the washer in the solenoid valve. Sometimes it leaks by enough to freeze in the dispensing tube.
Posted on Feb 26, 2009
  • 39 Answers
SOURCE: No water coming out
check power at the water pump. It is two of them one for icemaker, one for water dispenser. Pump located on the back bottom left....you need a 1/4 nut driver to take bottom panel off. Check power when someone else push water dispenser botton on the front of thr fride...if it is power you have to repalece whoe assembly, if it is not you have dig in deeper in to door dispenser...any question please ask, totalcarefl@yahoo.com
Posted on Aug 23, 2009
  • 180 Answers
SOURCE: ge ice maker wont make ice , no water entering
Take the front cover off of the ice maker.  Under the cover there are some test points,  V stands for valve and should have 120,  L stands for line and should have 120,  N is nuetral and should have continuity to ground. If all of these check good replace the ice maker, If not troubleshoot the wiring.  The fastest way to find out if it is the ice maker it to jumpre the two middle terminals on the ice maker plug.  If it spits out water replace the ice maker.
Posted on Oct 25, 2009
  • 5370 Answers
SOURCE: I have a SRS615DP Samsung
Turn off the main water supply line to the ice-maker and see if its still leaking.If its stop leaking then the possible option for leak is either the valve behind the ice-maker or the water supply line tube is cracked and this is leaking the water. I will explain the problem in detail.At the back of ice maker unit there is a water valve.When the ice maker unit dispense the ice,at that time this valve opens and water gets filled in the ice maker unit for next lot of ice to be made.This valve gets command from main control board of the refrigerator unit.This valve only opens for seven second to fill the water, and then it closes so water does not overfill.But in case if this valve is not getting closed then water will overfill and it will leak.So one possibility is to check this valve.There are two valves.One is main valve and one is this valve at the back of ice-maker.The main valve is where the water starts flowing,this main valve is at the back of fridge section.But you have to check the water valve at the back of ice-maker section.Now the other possibility,that is the water passing tube.This tube starts from main valve then this tube goes to water valve at the back of ice-maker then from there it enters the ice maker chamber.But if this tube is cracked or kinked or its got loose then it can leak water from where its loose or kinked.In some cases this tube is just got loose from its connecting hose so the water leaks due to that.Simply connecting the tube to its hose helps.But it has to be checked to confirm the problem.Its a plastic tube so it can get easily cracked or broken.----------- This are the two possibilities due to which the water can leak or overflow and leak from ice-maker section of Samsung refrigerator.----------- This troubleshooting will help to confirm the fault.Thanks.Helpmech.
Posted on Jan 13, 2011
I have a very small dribble of water leaking from the bottom of the control panel on the freezer door. Is there a simple fix or do I need a technician? Unit is a SRS615DP.
Maybe and maybe not.
Page 9 of the user manual mentions a anti sweat heater that you can turn on or off.
Samsung SRS579NP User Manual Ice cold Water Dispenser
It maybe that the water line to the water dispenser is leaking
I am including a link to youtube videos about refrigerator water leaks but there is little about Samsung. Hopefully turning on the heater will solve your problem. At least one of the videos shows how to replace the tubing in a different brand of refrigerator.
samsung side by side water leak from freezer door YouTube
Sep 29, 2014 | Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Samsung side by side fridge/freezer ice and water is not working after filter change
If your water and ice maker are not working, you may not have turned your water valve back on. If your water valve is turned on, try rotating your water filter further so that it completely locks as it may not be installed all the way. Once it is completely installed, press the "water" button for approximately three seconds until it turns blue. If this does not solve the problem, you may have a bad filter, here is a replacement filter that you can purchase to install into your refrigerator: http://www.freshwatersystems.com/p-3658-swift-green-sgf-dsb30-compatible-samsung-da29-00003b-refrigerator-filter.aspx
Jun 23, 2013 | Samsung RSG257AARS (241 cu ft) Side by...
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
Replaced DA29-00003B water filter in Samsung Refrigerator (RS2530BBP), with DA29-00003G filter. Water comes out extremely slowly....any suggestions? Tried holding ice type button for 3 seconds and...
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Jun 04, 2011 | Samsung AquaPure DA2900003A Refrigerator...
We are contemplating buying a samsung fridge However we currently have a whirlpool with the water filter on it. How would we disconnect the water filter currently installed to connect a new samsung fridge?
I'm not sure I understand your question, so forgive me if I'm incorrect. I'm confused as to wether your whirlpool has an internal filter or if you have an external stand-alone unit.
I have a samsung refridgerator and the water filter is inside the fridge located at the back on the upper right. In fact, all Samsung RAF/AES models come with this internal filter. Depending on where you buy it, often times the delivery guys will set it up for free. They will simply disconnect your old fridge, remove it , reconnect the water hose to your new Samsung and be on their way.
If you choose to do it yourself, simply remove the old fridge, follow the hose to under your sink and remove the old one. Run the new house by attaching it to the appropriate place on your sink and over to the back of the fridge. Also, many modern homes have a cold water tap behind the fridge, so you might be able to connect it there if you do.
Either way, whether you have an external unit or inyernal hose
Apr 03, 2011 | Samsung Refrigerators
Samsung RS267 Icemaker too slow - not waterline
Hthere........sounds like your settings are all askew.....however help is at hand....simply log on to ww.samsung.co.uk (if your from the uk) go to product support.....enter your model number....and hey presto they present you with an online manual which you can print
regards Sir Galahad
Aug 16, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung VRT Steam FabriC Softener not dispensing
My fabric softener intermiitently was left with clear water in the tray. The serviceman replaced the tray which did not fix the problem, he then replaced the valve assembly. That fixed the problem for about a year and now I am experiencing the same problem. Being the unit is now out of warranty, I purchased a valve assembly and replaced it but what I found in the process was that the real problem was that after removing the filter screen where the hose connects I found a SECOND mesh filter that was plugged up. I removed it with a needle from the edge so I didnt damage the screen. I think you could also just used a spray bottle with some water and a Q tip to clean. I wasted $50 on a valve assembly, but I did discover this second filter screen that is not mentioned in the user manual. Hope this helps someone because I have not seen this solution posted anywhere.
Jul 26, 2009 | Samsung Washing Machines
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
