Question about Maytag Washing Machines
Clothes stuck under agitator - Maytag Washing Machines
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 02, 2012
rpbuice
  • 161 Answers
SOURCE: need to remove agitator
Check on the side of the agitator on the lower half for a small set screw. It's hard to see but you can feel it. remove this screw and the agitator should come out.
Posted on Dec 17, 2008
  • 36 Answers
SOURCE: several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Posted on Jan 04, 2009
SOURCE: clothes stuck under the agitator
The clothes do not go under the plate they spin out of the top and fall over the side, this is because socks and underwear are either overloaded or spun out, this can be solved by reducing the load size and also spinning small clothing items on lower speeds, but the solution above is very helpful for getting the clothes out, but you will need a long pair of needle nose pliars to pull the clother out of the bottom of the tub. This problem presented itself by a "LD" error (long drain) Thanks tzweeb and I hope this helps others
Posted on Jan 09, 2009
srsrs_1999
  • 9 Answers
SOURCE: Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Posted on Apr 30, 2009
  • 157 Answers
SOURCE: clothes get caught under
Check the rubber gasket around the agitator is not worn. If it is get a replacement and insert it in snugy.
Posted on Aug 16, 2010
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
I would try to get clothes out, even if destroyed first. Otherwise,
there is a plastic cover cap on the top of the agitator. remove
by unscrewing or prying off. Hold down nut is exposed and remove
carefully, gently and with a ballanced pry up from underneath to raise agitator.
The agitater is not solid and clothes catch under the arms on the bottom and tangle and have even ripped. What can be done about to stop this? It seems like a design flaw to me.
It is not the best of designs.
Sometimes, clothes will get stuck at the bottom when the agitator dogs are worn out. Check to see if the upper part of the agitator is working during the wash cycle. If it isn't, the clothes stay at the bottom and just move horizontally, not from the bottom to the top. The clothes then get stuck in the gap between the lower agitator vaens and the bottom of the agitator. This is a very easy repair, you need only a socket wrench set (SAE) with an extension.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/2744
You can also buy the dogs (pawls) by themselves in a pack of four for about $5.
When I first saw this agitator set-up, I asked myself, 'What were they thinking of?'.
Good luck.
Mar 09, 2011 | Estate TAWS800JQ Top Load Washer
Whirlpool cabrio washer - a piece of clothing is stuck under the agitator - how do I get it out
Take off the cap on the agitator and remove the bolt. The agitator should pull off and you can rescue your clothing item.
Manual and parts list click here.
Hope this helps.
Zeppelinx12
Feb 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Clothes stuck under agitator pan
You'll need to remove the agitator.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Washing Machines
Clothes stuck under the agitator
you really have clothes stuck under the "wash plate" it has almost zero clearance and would be very hard to get something stuck under the wash plate.
if you do have something stuck, then remove the 1 1/2 inch cap in the center of the plate, then a 7/16th bolt that holds the plate down. then grab the wash plate and lift up to remove it.
next time check your pockets and dont let this happen again, it could ruin the outertub by cutting a hole thru it and then leaking.
Jan 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Several pieces of clothing stuck under agitator.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Washer pulling clothes under agitator
The gap between the wash plate and inner basket has widened.
Part #WP285903 retail $65.75
Nov 05, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
