Question about HP LaserJet 1320 Printer
Hp 1320 don't stop printing
Hi, when I press the green button for auto test, the printer starts printing many papers until getting paper jam. Is there any solution for that?
    New Friend:
My hp printer 1320 always prints two papers one of them is white.
what caused this problem?
Posted on Feb 13, 2013
  • adan osman farah Feb 13, 2013
    my hp printer 1320 always prints two papers one of them is white.
SOURCE: HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Posted on Jul 15, 2008
RPFinney
  • 385 Answers
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Posted on Apr 16, 2009
  • 72 Answers
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Posted on Jul 22, 2009
57 varieties
  • 1653 Answers
SOURCE: Printer says Paper Jam but it is not
  1. Remove the paper from the paper tray.
  2. Press the Power button and then wait for the jam to clear.
    • If the paper jam cleared, try the print job again.
    • If the paper jam is not resolved, continue.
  3. Remove the rear access door. Press the handle to the right, and then pull out the door.
  4. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  5. Replace the rear access door.
  6. If the paper jam cannot be removed from the back of the printer, raise the product cover, carefully remove the jam from the front of the product, and then lower the cover.
  7. Re-load the paper in the In tray. Fanning the paper makes sure that the pages are not stuck together.
  8. Press the Power button ( ) to turn on the product.
  9. Open the document in the application in which it was created.
  10. Click File, Print, Properties, Printing Preferences click Paper/Quality tab.
  11. Verify that the type of paper specified in the Type is text box matches the type of paper being used. A paper jam might result if photo paper is specified in the Printer Properties dialog box, but plain paper is loaded in the printer.
  12. Click OK to try job again.
Posted on Sep 22, 2009
  • 119 Answers
SOURCE: Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Posted on Oct 19, 2009
Hi I have a HP LaserJet 1320 Printer and when sending multiple documents it is pausing between them. I have to press the Green button to make them print, until the start of a new document when I have to...
Is the paper size set on the computer for the size of paper you are printing to?
Usually if you have to give a 'thumbs up' to the printer is because it is trying to print on an different size paper.
Aug 09, 2011 | HP LaserJet 1320 Printer
Tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
on Jun 11, 2011 | HEWLETT-PACKARD Hewlett Packard P1102...
Trying to print A4 size paper, when print sent i keep needing to press the green button to get the print
What software are you sending the print from? This might be set to a different paper size which is why the printer is asking to press the green button to use the paper loaded in the printer.
Check the paper settings either in page set-up or in the printer properties when you are about to print.
Nov 17, 2010 | HP LaserJet 1320 Printer
Printer gets jammed in the middle of printing
My printer get jammed with a thick paper. I cannot see where the paper is.
Jan 23, 2010 | HP LaserJet 1320 Printer
After cleared paper jam, HP LaserJet 1320 prints blank pages
Yes you can replace the transfer roller, but check to make sure the roller is firmly seated into its holder and that the springs are contacting the metal shaft.
Good Luck
Nov 20, 2009 | HP LaserJet 1320 Printer
Paper jam - hp c4380
Make sure that there is no paper stuck inside the paper, try cleaning the rollers, if the issue stil persit perform the below steps. Reset the All-in-One to the factory default settings by using these instructions: 1) Press ON and CANCEL buttons simultaneously 2) Display reads ?Enter Special Key Combo? 3) Press BLUE button, Green button and Grey button 4) Press Grey button continuously until "Resets Menu" is displayed. 5) Press Green button. 6) Press Grey button until "Semi full Reset" is displayed. 7) Press Green Button. This should resolve the issue.
Sep 27, 2009 | HP Office Equipment & Supplies
Problem with HP 1320 printer
If the paper size in the word document is set to something other than "letter" example if it is set to legal. Then the lite is lit to let the printer user know it is waiting for him to place a sheet of legal paper in the printer, he does so and then presses the green button to start the print job. You can check this by going to "file-page setup" in word and look for the paper size setting.
Jun 24, 2009 | HP LaserJet 1320 Printer
HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Oct 27, 2008 | HP Deskjet 3915 InkJet Printer
Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
Feb 14, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
