Question about Lands Phones
My uniden dect 6.0 base station is not working
5 Suggested Answers
SOURCE: Phone says "Searching" and will not work.
como activar mute la pertada 2 sin vos
Posted on Jun 24, 2008
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
Posted on Aug 24, 2009
SOURCE: Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Posted on Feb 02, 2010
After power outage, phone shows time, no dial tone..Uniden DECT 6.0
Unplug the base station / charger for 10 minutes and then plug back in. It may reset. Also, check if the battery in the phone is fully charged. I had a power surge last year and unfortunately, it blew my base station and I had to get a new phone.
Nov 22, 2017 | Dect Lands Phones
How do I reset the message on my Uniden DECT 6.0 cordless phone?
Hello Miriam Taylor,
Listening to the message should be sufficient.
Mine wasn't a real message... I fat fingered the
base trying to INTERCOM to my wife's remote.
As I never intended to use my system as an answering
machine... I deleted it too...
If you look really closely at the 1,2,4 & 5 key on the touch pad of each wireless remote the (play) right arrow seen on the base
is adjacent to the 2 key... Press it...
Delete will be an OPTION above the SOFT keys associated with the menu words on your display... (off & message gone).
Then made sure MY ANSWER FEATURE was "OFF".
You will have to read the manual... (RTM, below).
Message access can be accomplished three ways...
at the Base, at any cordless station... and (off premises)
remotely from anywhere in the telephone network.
Hope this helps...
ELSE RTM.
My favorite site for FREE manuals
is manualslib (MUST provide actual model numbers)
No exact matches found Try these results
Uniden DECT 6015 Owner Manual
Amazon com Uniden DECT 6 0 cordless phone Office Products
Carnac the Magnificent
Jun 17, 2017 | Uniden Lands Phones
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Dec 19, 2016 | Uniden DECT 6.0 Cordless Phone
My answering machine keeps saying its full??how do I clear it or reset it??
on the base station there is a trash button (top right hand ) use that to remove unwanted messages
Feb 23, 2016 | Uniden Cordless Phone
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
We just bought a new uniden phone system and the Answering Machine keeps answering the phone after 2 rings. I set the base machine setting to answer after 6 rings but it didn't change.
If you have changed the setting on the base station and that did not work, power your base station off completely and try again if that does not work you have an out of box defect and need to exchange it.
May 06, 2011 | Uniden DECT 6.0 Cordless Phone ID
My phones went dead and went into searching mode. Phone lines are working just not base
Your base station is dead, this is common with Uniden phones. You will need to purchase a new base station. You can use the new base station with existing phones as long as you buy a compatible model.
May 03, 2011 | Uniden DECT 6.0 Cordless Phone ID
While talking on cordless other party's cell phone disconnected. Now all cordless Uniden phones are saying "Searching" and do not work - main phone rings but no caller ID.
Sounds like someone unplugged the power on the base station, or the power supply failed on that base station. Do you have a spare power supply? Is there power at the outlet?
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone
Lands Phones Logo
705 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
