Just got my lg ku990 viewty phone, (update for lg prada) and having trouble connecting to the internet on it. I'm on an o2 contract. Whenever i try to start the browser it says "connection failed". Any ideas? Thanks, Sammy
i have exactly the same problem. even when i have full signal, it says connection failed. how strange.
Comments:
Feb 18, 2009
- hiya! i had the same problem, but i've fixed it. all you need to do is go to the bit of the menu where there's 'brower' and 'google' and 'notes' and at the bottom there should be a sim card, it should say 'o2' go onto that. and at the bottom of that list is says 'get settings' click that. and it should send a text to o2, who will then text back with your WAP settings. this should also sort out your mms. x
-   I have the same problem i have an LG viewty from vodafone and I cant get the internet even when there is 3 bars, i have tried everything please help-   Guest
Do you have credit, if you do and it still does not work take it to a phone shop or to where you brought it from and tell them what is wrong with it and they should be able to fix the problem...
I have an LG Viewty ku990 and my screen is gone white.the screen is not cracked but the display is...
(More)
I have an LG Viewty ku990 and my screen is gone white.the screen is not cracked but the display is gone white...it should be black.
unable to connect to internet even with installed profiles. only wap. unable to connect to already...
(More)
unable to connect to internet even with installed profiles. only wap. unable to connect to already installed pc lg suite. jus had touch screen n main screen replaced it jus not doing anything other than send sms n mms.. cant connect google , short cut dont wrk says ïnvalid access". or un supported profile type even tho virgin have sent thru all apps
unabl to bluetooth connect without passcode. where would I find it or change it. I have tried my sim...
(More)
unabl to bluetooth connect without passcode. where would I find it or change it. I have tried my sim passcode but not accepting it
