Question about Lincoln Conveyor Oven - 1133-000-A
The converyor is sppeding even though it is still lshowing the correct time
Timer is ok but oven not working
Nancy,
I understand that you are having trouble with your oven, model# CPLEF398DCE, not working/heating, even though the display screen is showing everything to be working fine. I suggest you give your appliance a hard reset. You will do this by switching the circuit breaker off, that the oven is on, for 3-5 minutes. Once the 3-5 minutes has passed, switch the circuit breaker back on. The first thing you will need to do, is to set the time. You will do this by entering in the time and pressing start. Turn the oven on. If you are still having trouble with the oven not working/heating, I suggest you contact your local authorized technician to come and diagnose the oven, to see why it will not work correctly.
-Best Regards-
Jan 19, 2014 | Frigidaire Ovens
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
The Pilot Light on my Delonghi DEBIE 24 SS Electrical is on even though the oven is off - any idea how to correct this?
The pilot light stays on most none electric lighting for gas appliance, this is normal if you do not have an electric ingnition on your oven.
Hope this is helpful
john
May 17, 2011 | Ovens
Kenmore Electric Range Model 790.9092. After 9-hour power outage, unable to reset clock on control panel. It will light up the correct time, then go black. The manual states that the oven will not work...
Hello, krcondit2
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Mar 13, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My Maytag Gas Oven will not heat up very much. It's a 50/50 guess if the oven will heat to the correct temp. Sometimes it works fine, the other times it is not very warm at all in the ove, even after...
ello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Maytag CWG3100A Gas Single Oven
Older Maytag built in oven. starts and reaches desired temp, sometimes. Other times it never lites. electric igniter always reaches a glow
Even if the igniter glows... that doesn"t mean the ignitor is good. The igniter is wired in series with the oven bi-metal valve. Many times the ignitor will not allow the correct current to the oven valve for it to open... even though it is glowing. I would recommend replacing the ignitor first, you should be able to find one for under 40 dollars.
Aug 10, 2010 | Maytag Ovens
Oven will not light Whirlpool M#3F31OBEGN
Hello, even though the ignitor is glowing it doe's not mean it's working, Igniters should pull 3.5 amps to be working correctly and should have a brillient yellow glow to it, when an igniter gets old it will glow more of an orange flavor and will take a long time or not at all to light the gas :) Your ignitor is bad you should replace it. If you have any other questions or concerns please feel free to comment again. Good Luck. Mike
Jul 20, 2009 | Whirlpool Ovens
Whirlpool RF367LXS Ceramic Glass Range not working
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Feb 02, 2008 | Ovens
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Lincoln Conveyor Oven - 1133-000-A Logo
19 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
Illassist
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
