Question about Yamaha Audio Players & Recorders
Yamaha P1500 power amp will blow the 230V fuse right when power comes on.
I got this old amp from a friend who has not being using it fore some time after it broke down. I try to fix it now but the fuse blows right away. Is there any use to try to solve this or should I just throw it away??
  • Yamaha Master
  • 5,807 Answers
Hi Harald,
That amp could have a great value from your friend, being not thrown out
yet.
If you prefer to have a lasting relationship with your friend, you may need
to have it repair , if you can't.
If you prefer to repair, start by isolating components on the amplifier.
Conquer the power supply.
Isolate the transformer from the power supply , and see if the fuse
still breaks.
If still does , you might consider your first option
(cause you have a bad transformer)
But here in our country it is of No problem.these can be rewind as
the original winding.
If the fuse doesn't break then trace on the power supply rectifiers,
capacitors to the output transistors.
Take out the bad power transistors in pairs.
If these resolves the blowing of fuses.
then look for additional possible bad components around it.
You may have a channel busted , but at least you have one running.
It is for you to decide, to continue repair or buy the power transistors
and other extra components.
These would at least make your friend happy, if you can have it
running again.
Let us know what you find or needs further assistance.
Have a nice day!
Posted on Nov 03, 2012
SOURCE: amp blows fuses
The fuses are there to protect the internals of the AMP.....
Please check that the correct fuses are installed......
if the incorrect ones are installed then a fire may develope...
There should be a manufacturers lable on the external chassis that details the fuses to use....
Fuses now days can be slow blow or fast blow....so the correct fuses must be used.....dont increase the fuse rating past the chassis panel label...but make sure they are correct...if they are correct then the amp needs a service to determine where the peak loadings to the power supply are originating from...
Some one may have installed incorrect fuses in the past...
Cheers from YUBEUT
Posted on Nov 03, 2007
Thumbsmagee
SOURCE: peavey classic 50/50 keeps blowing fuses.
Rob,
I have a classic 50/50 as well and re-tubed it with JJ el84s, vintage teslas and mullard 12at7s. As long as you replaced it with EL84s, I can't imagine that the output would be increased enough to damage the OT. When I got my 6505 Combo, one of the 6L6s was bad, and it kept blowing fuses and howling like a banshee. I would think that an OT problem would result in a significant loss of output...or none at all. I've gotten DOA tubes from a few places. I would suggest swapping each tube out 1 by 1, until you find it...if that is indeed the problem...before you pay the cash to have it worked on.
Posted on Oct 29, 2007
  • 4234 Answers
SOURCE: marshall 8080 valvestate amplifier
There could be a short in the rectifier diodes or in the transformer itself. Can you take some measurements inside the unit?
Let me know.
Dan
Posted on May 29, 2008
  • 16 Answers
SOURCE: my bass guitar amp is blowing fuses
Hi ! I have a soluution and it is about to be published on http://www.howtodothings.com/electronics/how-to-fix-your-guitar-amplifier
Please check in a few days time
Posted on Dec 04, 2008
  • 54 Answers
SOURCE: Carver M-1.5t amp. blows 15 amp fuse.
First off....you didn't say if you are a tech or not. I'll make this really simple.
If you are not a seasoned tech with experience solving carver problems....you will waste tons of time and money guessing what the problem might be.
Carvers are quite the unique beast. They deliver whopping amounts of power in a small chassis. This is done by using a trick switching power supply. There can be any number of possible problems.
To properly diagnose this you will need an oscilloscope, signal generator, variac, and of course a really good quality multimeter that can test diodes and transistors.
IF and only IF you are a seasoned tech with all the above equipment, that has no experience repairing carver, then go online to ebay, find member techman777, and for around $15 you can get a nicely reprinted service manual. Troubleshooting expertise and the manual will take you foreward from there because the manual has a very thorough troubleshooting guide in it.
If you think you can fudge your way through the guide without any serious electronics knowledge, you are in for a rude shock as you will find that you are an earth man trying to read martian.
If you are just a casual fix it guy ( nothing wrong with that !!! ), I strongly suggest that you do NOT make this your first try at fixing an amp.
The value of these, in mint condition, all rebuilt is around $350- $450 on ebay all day long. if you are willing to invest that much, you can look up carver audio repair on google and send it off to them, as they are reported to do a nice job. OR....you can look me up on ebay, send it to me and I will do a nice job too, and that comes from 20+ years of repairing.
I know that this isn't much help, but carvers are very special, and require special knowledge to repair.
Best of luck.....Rob
Posted on Dec 16, 2008
Why is induction motor saw blowing fuse shortly after starting?
If it is still trying to run as a DC system, it might be that the positive and negative are reversed.
May 03, 2014 | Saws
Do i have the right fuse
This speaker at full power draws average 1.3A at 230V and 2.5A at 120V. Mackie's recommended fuses are in line with this so your fuse is actually too high a rating. It is possible you are using cheap fast blow fuses or are over-driving the speaker (which should cause the fuse to blow) These speakers are only capable of 118db sustained (@1M) so cannot be expected to cope with anything but small venues or gentle music.
Dec 07, 2012 | Mackie Srm 350
I got a Marshall MG100HDFX for free from a friend stating it was blown. I asked how this happened and he said that one of his friends plugged in another speaker or amp into the second speaker input in the...
The power amp section has blown parts. You will likely find they use a chip like the TDA7293 as the power amp output and it will be blown, shorted causing the fuse to blow. These cost $6 from Digikey.com. Find a competent tech to replace it and use heat sink compound. Verify the part before ordering one. They come with leads bent either way so make sure you get the one with a matching suffix letter. When firing up after repair, put a 60 watt light bulb in series with the hot power lead to act as a current limiter... saves blowing fuses if there is another problem.
Jun 21, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a visonik 800watt amp and i got it from a friend for free and i hooked it up right and as soon as i turned it on the 2 fuses blew then i replaced them and tryed it again and it stoped again so i...
Its the amp, do not put any more fuses in it
you need to get it checked out by a technician.
Its probably a power supply fault or blown output devices.
Hope this helps
Thanks for using FixYa
Aug 02, 2010 | Visonik V2508 2-Channel Amplifier
1993 Yamaha GTS keeps blowing EFI fuse (10 Amps)
The EFI fuse, powers the ECU, the injector 12V feed, and the fuel pump. If it does it within a few seconds of trying to start the bike, it is the fuel pump. The bike has been stored for a while and the old fuel has gummed up the pump rotors, which stalls the pump and blows the fuse. If it is whilst it tries to run, then a short on the injector feeds or ECU wiring loom is favourite...do not try a 20A fuse
Dec 28, 2009 | 1998 Yamaha GTS 1000 ABS
Automotive wire in line fuse keep blowing fuses
sounds like eithor over draw or short
yes you can over draw the wires
Dec 21, 2009 | LG Art Cool LA1000PR Air Conditioner
Pluged into the wrong voltage
You have to replace the power supply with exact voltage and amperage.
Be careful next time.
Regards;
Hassan
Jul 27, 2009 | Fender Passport P-51 Consumer Microphone
Hafler power amp has one side out. Would like local repair.Series 9300.Approx.10-15 years old.Not used much.Second time to blow.Runs 4, 8om speakers including 2 bose 802,s (no bose controller or eq in...
just discovered same problem with my Hafler DH-200...right channel out but no obvious problems inside (no loose/burned wires, components, etc). Driven by Hafler pre-amp, but definitely power amp problem.
Sep 03, 2008 | Audio Players & Recorders
Minimal sound from subwoofer
MAKE SHURE YOU HAVE TOLD THE AMP YOU HAVE A SUB IN THE SET UP MENU UNDER SPEAKER SETTINGS.
IFF YOU ARE USEING SMALL SPEAKERS THEN SET THIS IN THE MENU AND OUT PUT BASS 2 SUB ONLY ,SET XOVER ON AMP IFF U CAN 2 120HTZ, ALSO CHECK THAT YOU HAVE THE SUB CABLE PLUGED INTO SUB OUT ON BACK OF YOUR AMP ,AND NOT THE 6 CHANNEL INPUT.
HOPE THIS HELPS.
CABLE GUY.
Apr 05, 2008 | Yamaha HTR-5650 Receiver
282 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
