Sharp mx 2310u L8:20 error
L8:20 error reprorted, very often, used on USB Printing which is shared over a network not directly on network. All boards removed and reseated, all connections removed and reseated, Latest firmware installed, Error message appears (not all the time) when a print is sent, Turning the achine on or off solves it for a short while usually hours. Any one got any ideas on this as its really bugging me and the customer.
  • 2 more comments
  • Steve Gwynne Nov 04, 2012
    Monday going to remove off usb and get it onto the network to see if it is anything to do with usb
  • Steve Gwynne Nov 07, 2012
    Solved this problem MFB board, and swopping the eprom and memory onto a new board which is
    an updated board. The visual difference is the ram slots, on the old board there is only one slot and slot 2 has the solder points but no socket. THE NEW BOARD HAS TWO PHYSICAL SOCKETSFOR ADDITIONAL MEMORY. DONT FORGET TO CHANGE THE SDCARD HIDDEN UNDER A SMALL METAL COVER ON THE BOARD.
  • Steve Gwynne Jan 21, 2013
    If any one gets this sort of problem for future reference a mass mixture of problems and codes all steming from L8-20 change the scanner board. Seems to be faulty on a lot of machines.
5 Suggested Answers
SOURCE: "Off-line" error message
Go to control panel - printers. Right click your printer icon - select delete printer. Reinstall the software and drivers via CD supplied. May have to restart your computer when complete. Go back to control panel - select printers - select add a printer and follow the instructions. When finished print a test page.
Posted on Nov 07, 2008
CopierOne
  • 30 Answers
SOURCE: H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Posted on Sep 06, 2007
  • 15 Answers
SOURCE: sharp ar-m276 printing error message
There is a known problem with adobe 7 printing on this model. Unistall the PCL6 driver and re-install it using the PCL5e driver instead. This will fix your problem.
Posted on Oct 17, 2007
  • 54 Answers
SOURCE: Windows Vista Printer Driver
Go to: http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
and select the copier and OS that you use. Download the PCL5e driver. When you finish downloading, you might have to extract it from the zip format, then run the setup.exe file and follow the prompts.
Don't forget to rate your answers please!
Posted on Mar 16, 2008
How do i clear error code F2-64
The news is not good. Follow the link to see what you are up against.
Error Codes Sharp MX2310U Code F2 64
Mar 04, 2015 | Sharp MX-2310U Color Copier, MX2310U "
Sim 66-10; What does The confidential data mean?
The MX-2310U offers Confidential Printing, which when used, requires users to enter a PIN code in order to print a queued document. To help protect your direct-print documents from unauthorized viewing, the MX-2310U offers encrypted PDF printing and scanning. Additionally, Secure Fax Release ensures received fax documents are held in memory until an authorized user enters a PIN code, so that compliance with healthcare regulations such as HIPAA is easier.
This data will be cleared if Sim 66-10 is enacted.
Mar 01, 2015 | Sharp MX-2310U Color Printer : 2310U
"Sim 66-10"; What does "The confidential data" mean?
Sharp mx-2310u printing double vesion of an image, the copy and the lighter to the right. how can i fix this?
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
Aug 27, 2014 | Sharp MX-2310U Color Printer : 2310U
I have used Mx-2310U (copier, scan, print). It is not work now. I see error code L4-06. So. I thought out the Manual, but I don't know solution of this problem. I am very busy. Please answer as soon as...
Dirty or broken sensors in the inside back of your machine that detect movement of your mylar transfer belt. A portion of the belt swings up and down for color printing. Or your belt unit may be broken or not installed properly
Oct 24, 2013 | Sharp Mx-2310u Color Copy/print/scan
L4-06 error
laser problem, call a tech
380 people viewed this question
k24674
