Question about Disney Princess Little Mermiad Talking Vanity
I need new blue plastic key to Disney vanity made in or around 2008 mp l#61248 vanity will not work electronically without.
Thank you for any help. abcdne78@aol.com
How do I change the battery in ignition key for my 2008 xb scion?
I have two Toyotas and both of their keys start flaking out in the 4 to 5 year time frame. One of the cars is a 2009 Scion xB. Changing the battery is something a user can do but there are a few things to be careful about. Before disassembling make sure you are not in an area that can generate static electricity otherwise you risk blowing out your remote circuit. Lay out a sheet of aluminum foil and do all your work on it so that everything is at the same voltage potential. 1) remove the key from any keychain. 2) Near the keychain side of the key is a tiny slot on the edge. If you put a small blade screwdriver in this slot and twist it will pop of the case cover of your key's remote electronics. 3) The electronics module is inside the key with it's own plastic housing which pops right out of the key shell. 4) Once you have the module out notice that one side is black plastic while the other side is clear plastic. There are five edges to the module and on one corner is a small clear plastic tab protruding up. To the right of the tab is a hard to see but small slot where you must insert a small screwdriver to gently separate the tab underneath. At the same time, pull upward on the protruding tab and the clear plastic shell with the electronics should start to come out. Once apart the battery is visible, a CR 2016 watch battery, available usually at Target, Wal-Mart or any electronics store for ~ $2. Install the new battery and reverse the procedure and you should be good to go.
Feb 12, 2012 | 2008 Scion Xb
Need manual for Disney Little Mermaid/Ariel Beauty Salon and the mirror will not light up
look in the internet and find the manual. in the manual you can find how to light the mirror
Dec 26, 2010 | Disney Princess Little Mermiad Talking...
Hi, I bougth my new Volvo S40 in 2008 and never had any problem since then. Today, I found that I can not open the trunk, although the rest of the doors open fine. The central locking systems works...
If it is the same as the 2007 model.
The top of the key is a small slide switch.
You slide it and pull a vanity key out.If the glovebox has been locked it also possibly locks the boot with the same switch.
You will probably need to put key in glovebox lock and turn counter clockwise.
That key is to lock the seats to stop anyone getting into the boot via the fold down system as well.
Hope this helps.
Sep 10, 2010 | 2008 Volvo S40
Need a new plastic cover for the motor/electronics part.
Hi Linda
Here is a telephone # for Precor Austria +43 64 52 3900 or you may directly email www.intlcustsupp@precor.com.
Mar 08, 2010 | Precor 9.21 Treadmill
Disney Cars
Unfortunately, there are no remote codes available for Disney electronics because the company that actually manufactured the TVs and DVD players carrying the Disney name was a no name company that didn't bother working with the companies that manufacture universal and cable remotes.
Jun 27, 2009 | Disney 13" TV
Disney princess 13" tb p1300 ntv
disney will replace for around 30 dollars. Google disney customer service and get number is you are interested.
Apr 07, 2008 | Disney 13" TV
Disney Princess Little Mermiad Talking Vanity Logo
44 people viewed this question
Top Disney Toys Experts
Nikki  Mclean
Nikki Mclean
Colin Stickland
Colin Stickland
Are you a Disney Toy Expert? Answer questions, earn points and help others
