Question about Magic Chef Refrigerators
Hole in coolant line magic chef stainless steel refridge
Hole in coolant line gas leaked out
    Top Expert:
  • Magic Chef Master
  • 9,472 Answers
You will need to purchase a new unit.The problem when moisture and oxygen enters the sealed system, it breaks down the refrigerant into hydrochloric and hydrofluoric acids, which then in turn damage the mechanical components. You have a major problem, and I'll save you a house call charge by telling you that the entire sealed system has to be replaced. If you only have the system evacuated and dehydrated, then recharge the system, which even if its done properly and legally, by an EPA Certified Type I Technician, in other words, not recommended for a DIYer, due to the process required, would still be a major repair, and would not last as long as it should due to the acid damage.
Posted on Nov 02, 2012
  • 1462 Answers
SOURCE: hole in freezer
there is a way using a special resin but it is not a reliable repair and you will then need special gear to regas
write it off
Posted on Aug 31, 2008
woodchuck789
  • 4059 Answers
SOURCE: Is there a replacement part for the freezer
The evaporator can be replaced and a damaged line can be repaired. It's not cheap as a qualified tech will have to recharge the system besides the repair. With the proper model number you can look up parts here. http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a Model number help here. http://www.appliancepartspros.com/modelnumber_locator.aspx
Posted on Aug 22, 2009
heatman101
  • 43501 Answers
SOURCE: my magic chef refridgeator/freezer is no longer
You compressor is clicking trying to start. The insides of the compressor have siezed up meaning that they will not let the motor run and turn them. The motor trying to run and not being able to makes it very hot. Unplug it and let it cool down over night, it may go for a while then, but it is probably terminal. Getting the compressor replaced will cost almost as much as new. Is it possibly under warranty?
Posted on Nov 12, 2009
Testimonial: "was what i was afraid of, Thanks so much. Pat"
DeBruce
  • 145 Answers
SOURCE: how do i get scratches out of my stainless steel
Try a 3M scotch brite 7447 pad you get at auto parts stores etc. go with the grain of course. If that wasn't aggressive enough go to 180 grit sand paper with the grain. When scratch is removed use DeBruce Polish for daily cleaning of all your stainless steel, perfect in the kitchen. DeBruce Polish is non-toxic and odorless. Also use DeBruce Polish on CERAMIC COOK TOPS, glass polished marble and granite. We get Debruce polish at debrucepolish.com.
Posted on Dec 30, 2009
  • 454 Answers
SOURCE: chipping away ice in magic chef freezer section i
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Posted on Feb 06, 2010
How to set up the clock?
No sweat, really easy. press clock button once for 12hr twice for military time, then enter time, press clock button again.
Magic Chef MCD1611ST Instruction Manual Controls Setting The Clock Time...
Mar 31, 2015 | Magic Chef MCD1611ST Stainless Steel...
HOW CHARGE GAS TO REFRIGERATOR?
First you have to leak test it
If you have lost refrigerant, may as well
buy a new one
ALL refrigerant work has to be done
by trained people
NO Refrigerant products come with provision
to attach hose gauge assy
You have to add clamp on or solder on line taps
Not worth doing & if it has R22 it has been band
as of Jan 2014
May 12, 2014 | Magic Chef MCBR360S Stainless Steel...
MAGIC CHEF REFRIDGE
What is the complete model number of your unit?
Dec 04, 2012 | Magic Chef Refrigerators
Coolant system has a small hole gas leaked out
Nov 02, 2012 | Magic Chef MCBR360S Stainless Steel...
My magic chef mcbr445s will not cool down the compressor NSA30la cg stays hot what should i change out
check the condenser fan if working good or clean you condenser unit use water from faucet
Feb 24, 2011 | Magic Chef MCBR445S1 Stainless Steel...
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
No heat on magic chef microwave
Check the door safety interlock switches.
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Hole in freezer
write it off
Aug 31, 2008 | Magic Chef MCBR440 Compact Refrigerator
Refrigerators Logo
358 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
