Question about Magic Chef MCBR360S Stainless Steel Compact Refrigerator
Coolant system has a small hole gas leaked out
  • alan wade stephens Nov 02, 2012
    Poked very small hole in coolant line gas leaked out can I fix it with Epoxy
    Top Expert:
  • Magic Chef Master
  • 9,472 Answers
The problem when moisture and oxygen enters the sealed system, it breaks down the refrigerant into hydrochloric and hydrofluoric acids, which then in turn damage the mechanical components. You have a major problem, and I'll save you a house call charge by telling you that the entire sealed system has to be replaced. If you only have the system evacuated and dehydrated, then recharge the system, which even if its done properly and legally, by an EPA Certified Type I Technician, in other words, not recommended for a DIYer, due to the process required, would still be a major repair, and would not last as long as it should due to the acid damage.
Posted on Nov 02, 2012
What does PO442 and PO463 codes mean
PO442 indicates a fuel vapor leak in the EVAP control system. It means a very small leak has been detected. In fact, the leak can be from a hole as small as 0.04" in diameter. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.A code P0442 most likely means one or more of the following has happened:
  • A loose or improperly affixed gas cap
  • A non-conforming gas cap (i.e. not factory/original brand)
  • A small leak/hole in a fuel vapor hose/tube
  • Other small leak in EVAP system
  • Faulty vent o-ring seal
With a P0442, the most common repair is to:
  • Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
  • Otherwise, replace the gas cap, or
  • Inspect the EVAP system for cuts/holes in tubes/hoses
P0463 Fuel Level Sensor Circuit High Voltage
Jan 26, 2012 | 2002 Cadillac Deville
Check engine light code reads 442. What should I check
DTC P0442 - Evaporative Emission Control System Leak Detected (small leak)
This indicates a fuel vapor leak in the EVAP control system. It means a very small leak has been detected. In fact, the leak can be from a hole as small as 0.04" in diameter.
The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine. You likely won't notice any drivability problems.
- A loose or improperly affixed gas cap
- A non-conforming gas cap (i.e. not factory/original brand)
- A small leak/hole in a fuel vapor hose/tube
- Other small leak in EVAP system
- Faulty vent o-ring seal
- Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
- Otherwise, replace the gas cap, or
- Inspect the EVAP system for cuts/holes in tubes/hoses
Hope this helps; remember to rating this answer and leave a testimonial comment. Thabk you for using Fixya.
Oct 14, 2011 | 2006 Buick LaCrosse
PO442
What does that mean?
This indicates a fuel vapor leak in the EVAP control system. It means a very small leak has been detected. In fact, the leak can be from a hole as small as 0.04" in diameter. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
FB.init("dd7d9e9681341cde77587bc6a2029f6f"); OBD-Codes.com on Facebook Symptoms
Causes
Possible Solutions
Apr 29, 2011 | Ford Explorer Sport Trac Cars & Trucks
What is an error code p0442 for a 2001 seabring mean?
Symptoms: You likely won't notice any drivability problems.
Causes: A code P0442 most likely means one or more of the following has happened:
Possible Solutions: with a P0442, the most common repair is to:
Check it, test it and send us news.
Apr 22, 2011 | Chrysler Sebring Cars & Trucks
Code po442. can any affected parts be tested ?
* A loose or improperly affixed gas cap
* A non-conforming gas cap (i.e. not factory/original brand)
* A small leak/hole in a fuel vapor hose/tube
* Other small leak in EVAP system
* Faulty vent o-ring seal
Possible Solutions: With a P0442, the most common repair is to:
* Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
* Otherwise, replace the gas cap, or
* Inspect the EVAP system for cuts/holes in tubes/hoses
Hope helps.
Mar 07, 2011 | 2005 Chevrolet Cobalt
My check engine light came on and it is a p0442 EVAP SYS, small leak
Keep us updated.
Dec 13, 2010 | 2004 Saturn VUE
Code, p0442 p0445
P0445 - Evaporative Emission Control System Purge Control Valve Circuit Shorted.
Possible Solutions: with a P0445, the most common repair is to:
* Bad or loss contact wires
* Check harnesses, replace it
Hope helps (remember to rate this).
Nov 05, 2010 | 1999 Jeep Cherokee
Location of sensor for troubleshooting po442 to cause check engine light to come on
P0442 OBD-II Trouble Code - Evaporative Emission Control System Leak Detected (small leak)
Symptoms
Causes
Possible Solutions
Fig. EVAP vent solenoid (2) on 3.1L, 3.4L, 3.5L & 3.8L, showing the connector (1) and vapor line (2)
Fig. EVAP canister purge solenoid location on 3.1L & 3.4L
Fig. EVAP purge solenoid valve (3) location on 3.5L
Hope this help, good luck.
May 11, 2010 | 2002 Buick Century
I have 2000 chevy impala 3.4 engine i have check engine light with this code p0442 took it it to auto zone they said it was a small leak dont know where to start
Dec 31, 2009 | Chevrolet Impala Cars & Trucks
Have a small leak in my small freezer unit coolant system
Good day,
Gas is not dangerous. But you have a serious problem.
Repair is limited to an epoxy repair, or replacing the coil assembly complete.
A new dryer filter must be brazed in, The system must be vacuumed out, charging ports installed ect,ect,ect.
You can call around to the service companies for a price, but it will be pricey, and you will probably have to take it in.
Not considered to be a practical repair.
Dec 24, 2009 | U-Line 15R Compact Refrigerator
Magic Chef MCBR360S Stainless Steel Compact Refrigerator Logo
90 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
