Question about Whirlpool Duet GHW9150P Front Load Washer
Gibson front load washer will not drain. All other functions operate. Machine is about 10 years old.
  • kytyn Jan 28, 2009
    The same thing happened to me this morning - the machine is about 10 years old and the service number on it no longer exists. I've tried just running the spin cycle multiple times but the water won't drain.
  • rdpackwood Feb 13, 2009
    Gibson Front Load washer Model GWLT445RGS1 : Water won't drain and I have checked for obstuction and thats not the problem.
    Help
Does it drain if you lay the drain hose down in the floor..If so that means that there are no restrictions from water pump on throught the end of the hose.I would check underneath the washer to confirm that the belt isnt loose or broken.If that is okay It will either be the water pump or the program timer if it is a manual with a turn knob.P.S. maybe its time to purchase a new one if you can,t do the work yourself..
Posted on Jan 04, 2009
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
Washer won't spin. 2 years old.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 07, 2011 | Kitchen Ranges
The tub won't drain and it spins very slowly. I've also noticed, over the last couple years, some oil/rust spots on my clothes. It is a top loading washer that is over 20 years old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 13, 2010 | Amana Washing Machines
I have a Kenmore top load washer model 20692. The washer won't drain and whenever the washer is supposed to turn all I hear is a hum. What could be the problem and is it worth fixing in a 10 year old...
Sounds like you have multiple problems...you are right... probably not worth fixing...
Look at the front loaders... they use way less water and are more gentile on your clothing...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 08, 2010 | Kenmore Washing Machines
Machine not draining
heatman101
Jun 04, 2010 | Whirlpool AWM5145/2 Front Load Washer
I have the front loading Maytag and was using HE soap but with maybe too much Shout detergent to clean some stains. for the first time with my maybe two year old machine, some limited suds came from the...
Hi Mike. I am Kelly. I noted you went the chat route first before your p;ost ended up here.
Take the drain hose from the drain and maually drain the machine until you can not get any more water out of it. Then unplug the machine for 5 - 10 minutes so that the filter sensor will reset. For some unknown reason it seems the sensor is working but it did not trip and error code on the display panel.
If it still does not work after the manual drain you may have to open the filter door and open the filter to allow it to completely drain and do the same 5 - 10 min plug out of wall / power off routine.
Kelly
Mar 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal De
