Question about Denon DN-S3500
My cd will not go fully in when trying to load
When i put the cd in it does not go all the way in as the cdj should pull it in and it does not? i try to push but it wont work.
Cdj 1000 keeps ejecting the cd
Does it ever finish loading- any indication of that?
Dec 20, 2012 | Pioneer CDJ-1000 CD Player
When i turn on my cdj 400 it automaticaly ejects and loads cds constantly even tho theres no cds in it ?? it only stops once you load a cd or use the usb help plse..
That is really weird. so it says ur putting a cd in and ejecting the cd?. im not sure about those models but if theres a reset on it i would try that before sending it out.
May 20, 2011 | Audio Players & Recorders
I just got a cdj 1000 mk2! when i put in the cd, the cdj turns off and on and off and keeps this cycle going until i eject the cd. If i don't put in any cd, it's fine. but as soon as i put in a cd it...
I'm having the same problem. Just started like 2 weeks ago. I've had my MK2s since March.
I tried switching AC Power cables, it seemed to help, I have new cables on the way but I don't think that's the solution. I've read that the MK3s are having a similar problem, related to a fuse.
Oct 18, 2010 | Pioneer CDJ-1000 CD Player
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Aug 09, 2010 | Pioneer CDJ-200 CD Player
My cdj 800 is not reading cds.
Hii,
Please try to clean laser and compartment of your CDJ. Also, make sure if you can open ur deck and fix it again. If it does not work and u get any error msg too. pls let me know.
I hope this will work.
thx
djajay
Aug 08, 2010 | Pioneer CDJ-800 Turntable
Eu tenho o cdj 100 s pionner que deu problema no leitor troquei os leitor uma funcionou e a outra não o que sera me ajude
hello frnd,
can u pls post ur complete problem. what error u get. does cds play or not. how old ur cdj's
thx
Aug 07, 2010 | Pioneer CDJ-100S CD Player
My cdj 800 is having a problem with cd reading.its not reading cds as it was new..just 1 year nw for my player.if put cd inside it cums out afetr 2,3times if i insert cd inside then it getging read......
Sometimes so CD does not play in certain CDJ, i have 2 or 3 disc which
does not play or eject when i try to play in CDJ 100s but when i play them
in another player they go well.
Pls try to have some other brand disc or you may clean compartment of the CDJ their may be dirt inside CDJ. I hope this will help.
thx,
djajay
Jan 29, 2010 | Pioneer CDJ-800 Turntable
Cdj 1000 mk 2 cd won't go in front load tray
sounds like a cd slot mech problem,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Oct 05, 2008 | Pioneer CDJ-1000MKII CD Player
Cdj 100s cd players
try clean it with cleaning disc...than try to load some original cd....if it comes again your laser is dead
May 08, 2008 | Pioneer CDJ-100S CD Player
Denon DN-S3500 Logo
18 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
