Dvd without coaxial, old tv without RCA, passthrough VCR died
I have an older tv with only coaxial, no RCA. I have a DVD player without coaxial. I've been playing DVD with a passthrough to the VCR which has both coaxial and RCA. My VCR no longer works (won't power on). The tv and dvd players work fine. What do I need to buy to make them work? I don't even care about the VCR to play or record VHS, as it was used only as a passthrough anyway. I've been looking online and realizing a cheap VCR won't have the coaxial either, just like the dvd player. Everything says to get an Rf modulator with the new vcr. Since I don't care about the actual VHS player/recorder, do I need only an Rf modulator? What exactly does that do?
  • alleynj Jan 04, 2009
    cenobite, that is exactly what I needed, and Radio Shack is on my way to the grocery store this morning! Thank you! I'll be working out to my DVD's again by tonight!
    Novelist:
  • 146 Answers
If you have a VCR you could run the coax to the TV and then plug the RCA connections from the DVD player into the VCR line in. Then you just have to have the VCR on and have the line in selected on the VCR. If you have no VCR you can get an RF modulator from Radio Shack for less than 30 dollars. With that you can connect AV component cables or S Video cables from any device and connect it to a TV with only a coax in.
Look here.
Cheers
Posted on Jan 04, 2009
    Sergeant:
    Champion:
  • 201 Answers
Http://www.ellies.co.za/v2/index.php?id=492
@ tihis link above you can see it. It takes the av SIgnal Your Sound and picture and convert it RF making it possible for your tv to tune it, its just like tunning into a station. I do sell these for R199 South African Rand excluding postage
Thank you for using FIX YA
I am having trouble connecting dvr to dvdvcr to older tv
This can get tricky sometimes. It depends if you're connected the DVR to the tv via RCA cables or coaxial cables. For coaxial, connect from the TV's in to the DVD/VCR combo out. Coaxial from your DVD/VCR in to your DVR out. set your VCR/DVD to channel 3/4 depending on your manufacture as well as your tv. If this doesn't work, usually your tv provider may be able to help you out.
Mar 01, 2011 | Televison & Video
Can't find where to connect for dvd. no white,yellow,or red plug.
Hello, Thank you for the opportunity to help
Sounds like you got a pretty old tv there, its frustrating not to see the RED/WHT/YELLOW plugs on it. This is because this tv was made when that was not out yet. So are you out of luck? No, you ar in luck but it will cost you a little money.
You can purchase one of these RF modulators at Radio shack for like $29.95.
OR
If you have a VCR, Generally they have these plugs out the back of them you would plug the DVD into the VCR in the Video IN. You're TV will need to be on channel 3 or 4 (dending on your vcr) You vcr will need to be powered ON then tuned to VIDEO INPUT. You can do this by using the remote's up/Down channels buttons or pressing input on the remote depending on the VCR.
The VCR will need to be connected to the TV's coaxe port on the back, That port looks like this:
If you do not have a VCR you would purchase a RF modulator you TV will need to be on channel 3! The modulator is connect to the port pictured above above. The DVD is then introduced to the ports on the back of the modulator witch looks like this:
rulds2008_40.jpg WE hope you found this Very Helpful. This was answered by a human being, That works hard answering FREE questions just for a Thank You!
Regards,
Rulds2008 "ED"
Jan 27, 2011 | Zenith Z19A11S TV
How to hook up dvd player to tv
You need an RF modulator to convert the A/V output (RCA jacks) of the DVD player into a Coaxial cable you can plug into the back of your TV. I'm including a link to one at radioshack.com. This one costs $27.49. You might be able to find a cheaper one at a discount store. You can also use an old VCR if you have one to do this conversion but the connections get a little bit tricky. Plug the A/V outputs of the DVD player into the A/V inputs of the VCR. You'll have to set up the VCR so it knows to use the A/V inputs. Some VCRs have and AUX setting for this. Then connect a coaxial cable from the VCR output to the TV input. You'll have to setup the VCR to send it output to a specific TV channel, usually channel 3 or 4. Then you'll have to set your TV to that channel.
http://www.radioshack.com/product/index.jsp?productId=2103095
May 21, 2009 | RCA Televison & Video
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Connect magnavox dvd to ge tv HELP!
What you will need is an RF modulator. They are relatively inexpensive and can be found at local electronic stores. The following link will provide you with a background on the device and how it functions and connects.http://hometheater.about.com/cs/dvdlaserdisc/a/aadvdrfmoda.htm I hope this has been helpful and thank you for using Fix Ya. If you need anymore assistance please let me know.
Oct 09, 2008 | GE 27GT271 TV
Video channel
Dear Gonedeep2,
Are you saying the DVD/VCR player does not have a coaxial socket?
Does your TV have RCA sockets to match the DVD/VCR player.
(ie. red and white for audio and yellow for video signals).
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Protron DVD REcorder
The coax output is just a passthrough. You need to go to the TV through the RCA output even if you have to go through a VCR or other component.
Jan 21, 2008 | Protron PD-DVR100 DVD Recorder
RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Nov 08, 2007 | RCA F27242GY 27" TV
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Televison & Video Logo
279 people viewed this question
Top Televison & Video Experts
Electro Med Services...
