Question about Daewoo Refrigerators
Daewoo side by side temperature indication
Own a new Deawoo FRS-U21FF .
temperature was in Celsius degrees on display .
Is now in Fahreneit degrees .
What's the procedure to go back in Celsius ?
( no instruction on user manual ).
SOURCE: Daewoo refrigerator water filter red light still on after replacing the filter
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Posted on Nov 12, 2007
  • 3 Answers
SOURCE: we own a samsung cooltech
Im no expert, but you can try this, take the back bottom cover off and you will see two drairn pipes going into a drip tray. remove those pipes ( just pull them down ) make SURE they are not blocked ( there is a rubber thing at the top that can close up--- just cut it open ) place a bucket under those pipes and leave your fridge off and the doors OPEN........ it may take a couple of days for ALL the ice to defrost. when you think its done--- leave it a few hours and if there is any water being collected --- you still have ice in there. i was amazed at how much and for how long water kept dripping out of the fridge drain pipe.... the pipe nearest to the compresser is for the frezzer, If the sensor that tells the fridge to get cold is all iced up it wont even try to get cold--- it thinks it is already.
Posted on Jan 03, 2009
SOURCE: Daewoo FRS-2031IAL instruction manual
Hold down the [ice make lock] and then the [lock] button simultaneously for 3 seconds. It took me a couple of attempts but I got there in the end (the manual mentions holding them down at the same time).
Posted on Apr 21, 2009
  • 144 Answers
Good news! Straight from the Daewoo website, here is the user's manual link for your Model FRS-2421IAL that you are looking for in an easily clickable and printable form. Just click the link below, look for your model number, and choose "manual".
Hope this helps!
- CBR2009
Posted on Aug 18, 2009
  • 3600 Answers
SOURCE: whirlpool 6 sense model WSC5513- A+ X side by
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Posted on Aug 20, 2009
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
My whirlpool side by side fridge freezer power cut alarm will not stop going off temp display is reading -7 degrees Celsius in freezer but I put therometer in it and that is saying -17 degrees Celsius...
Are you sure it's not a temperature alarm rather than power? Check the thermistor isn't in a block of ice, give the freezer a good defrost, and check the condenser is nice and clean.
Apr 25, 2014 | Refrigerators
Croc only heats up to 230 degrees is there a way to reset it
To Change the Temperature Setting from CELSIUS [230 Degrees] to FAHRENHEIT [450 Degrees]
If [230] appears on the display screen, then the temperature is set to Celsius. To change back to Fahrenheit:
1. Turn off your flat iron and unplug from electrical socket (wait for 10secs).
2. Then plug the iron back into the electrical socket.
3. Press & hold down the HIGH [?]button, then press ON/OFF button. An "F" will appear on the digital screen. Your device is now in Fahrenheit mode.
Jul 23, 2011 | Crocs Croc 2 Flat Iron Titanium Plates 1"
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Mar 22, 2011 | Microwave Ovens
I am trying to return the freezer and refrugerator settings to 37 and 0 , how do I do that?
There is a dial or button pad inside the fridge that controls the temperature up or down.
some displays are not so clear so just adjust your fridge slowly either way until you get to the desired temperature
37 degree Fahrenheit = 2.78 degree Celsius
0 degree Celsius = 32 degree Fahrenheit
Oct 28, 2010 | LG Refrigerators
Ice cream will not freeze, but will make ice cubes.
Actually, it's not as you think. Ice cubes are made between 0-4 degree Celsius and ice creams are frozen below -3 degree Celsius. Your freezer temperature may be between 0 and -3 degree Celsius and that is causing the problem. An ideal freezer should have temperature between -3 and -30 degree Celsius.
Apr 20, 2010 | Samsung RS2578BB Side by Side Refrigerator
I just changed the battery and I keep getting the temperatures in Celsius instead of Fahren. How do I change it to F?
You need to discinnect the battery and reinstall it. When you reconnect the battery press the 'SET' button within 15 seconds. The temperature reading will now be set to Degrees F.
See below.
Setting/Changing ºC and ºF Temperature Scales
The food safety thermometer can display temperature in either the °C
(Celsius) or °F (Fahrenheit) scales. The desired scale is selected at the time
the battery is installed:
Selecting the °C Scale:
When the battery is connected to the battery leads the °C scale indicator
shows on the display for approximately 15 seconds. If the SET button is
not pressed the unit will time out and default to the °C or Celsius scale.
Selecting the °F Scale:
If the SET button is pressed within 15 seconds of connecting the battery to
the battery leads, the temperature scale display will toggle to the °F scale
indicator and the unit will now default to the °F or Fahrenheit scale
Feb 28, 2010 | Fluke Networks Fluke/Raytek FoodPro Plus...
Trying to convert minus c to minus f in cal plus
Here are the formulas for conversion.
Let T_C be the temperature on the Celsius scale and T_F the temperature on the Fahrenheit scale.
0 _C correspond to 32 _F
100 _C correspond to 212 _F
  1. T_C =(5/9)*(T_F -32) ; for T_F=212 _F , T_C = 5/9*(180)= 100 _C
  2. T_F= (9/5)T_C + 32 ; for T_C=100_C, T_F = (9/5)*100+32 = 212_F
Problem for you : Find the temperature which has the same value on both scales.
Jan 10, 2010 | Texas Instruments TI-84 Plus Calculator
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
Aug 20, 2009 | Refrigerators
Refrigerators Logo
81 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
