Question about GE Heating & Cooling
Commercial air conditioner would fit in a balcony door?
If that does not work.What air conditioning unit would fit in a balcony door?
Unit exhaust air is cool
Is this in a commercial application and happen to be an economizer which I'm restaurants mostly they work by giving the hot building "free air conditioning" from colder outside air to save power.
May 28, 2016 | Haier HPR09XC7 Portable Air Conditioner
What does it mean when it says bucket full?
These condition units come with an internal removable bucket to catch the water from the condenser unit..and will shut off when full..must be emptied...should be on the bottom and hold about two gallons or so..should be easy to find..good luck.
Oct 05, 2014 | Haier 12,000-BTU Commercial Cool Portable...
Water dropping on air conditioner
Water is dripping on your ac from a duct? Or is the unit it self leaking Are you sure you don't need a Professional Air Duct Inspection?
If you are in the market for an Air Duct cleaning check out Air Duct Cleaning Dallas Tx.
Jun 10, 2012 | Heating & Cooling
Should my 10,000 btu window air conditioner be leaking water all over my balcony
Air conditioners put out cold air, exhaust hot air, and produce condensation when they are in use. The condensation is the water that is dripping out of your air conditioner.
Your air conditioner is not broken, but it would be wise to determine a way to direct the water off of the balcony.
May 22, 2011 | Whirlpool Heating & Cooling
Sir i want to tal with u please give me u id...and i ant t know York Air Condition Price list all and Spasiliy this model D3CE090A25A Capacity 7.5 T
You cannot have my ID...
Prices of air conditioning equipment varies greatly depending on your location, installation, and application. As a general rule, expect to pay several thousand dollars for a central air conditioner installation in a residence.
The YORK model you specified appears to be a 7.5 ton commercial rooftop unit...It would be best to call a local contractor for a bid. Any good contractor always gives free bids and will be able to tell you whether that model is best for your application.
Feb 28, 2011 | Heating & Cooling
Only blowing hot air and red light flashing on panel. Also no noise from the main unit on the balcony which is usually loud when a/c in use
Whenever there is problem in unit, the error code will be displayed. Please check. As per your statement, it's communication error between indoor and out door. Check power in out door unit.If not check your temp setting.
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working . Thanks.
Jan 07, 2011 | Heating & Cooling
Panasonic Reverse cycle Airconditioner
This operation should NOT be done by the home owner. If the unit has valves on the high and low sides to enable a pump down operation of the system (gage manifold required) to return all refrigerant to the high side of the system (condensing unit). If the system does not have valves it must have the refrigerant charge recovered from the system before it is disconnected. Call someone qualified!
Jun 03, 2008 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
