Connect Dell Inspiron One to TV via HDMI
When I connect Phillips TV to Desktop PC Dell Inspiron One 2320 i can't set up second monitor. The system don't see HDMI port. System: Widnows 7 Graphic: Intel HD Graphics and Nvidia GeForce GT 525M Thanks for help
SOURCE: Connect Dell Mini with HDMI to VGA PC flat monitor
hi,
you would need an HDMI to VGA adapter. sometimes it would come in a form of a separate cable or just a regular adapter which would convert the HDMI end to VGA (the blue one that has 15 pins)
you can purchase these cables from your local computer store.
hope this helps
Posted on Jul 12, 2010
steve6375
  • 395 Answers
SOURCE: Dell inspiron 1505 not supported wireless adapter in the system
Check Control Panel - System - Hardware to see if you have a wireless card listed under Network Adaptor.
Click on it to see if the driver is installed ok.
Does the laptop have a switch or function key to enable the wireless?
Posted on Aug 07, 2008
  • 27 Answers
SOURCE: nvidia geforce9400gt monitor problem
Usually the problem with windows 7. if you have 2cables connecting from youre monitor to the graphics card, unplug one of them, it worked for another guy
Posted on May 27, 2009
  • 742 Answers
SOURCE: MY PC DOES NOT HAVE A HDMI PORT CAN I USE MY PC
Look at the function keys (F1 to F12) in your computer since there is a shortcut key in it. Look for a key with an icon resembling like a TV and a PC Screen with a slash. It's like TV/Monitor icon.
Now with the PC (laptop?) hooked with the TV, (the tv showing no signal), hold down the FN key and press that function key with the TV/Monitor icon.
Posted on Jun 05, 2010
SOURCE: I have a notebook ASUS N61Jv with NVIDIA GT 325M
i have this problem !
plz help
Posted on Nov 21, 2010
How do I connect my dell inspiron 3847 running windows 10 to my tv
Wayne Vernon,
Since you do not mention the tv you are connecting to I cannot be sure about it. With that said you may need to go into the TV Controls and set the TV to HDMI 1 OR 2 and then see if that will correct itself.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 05, 2016 | Dell Inspiron 3847
I have amazon prime on my desktop can ihook it to my tv
You should be able to discount your monitor cable from the back of the monitor and then connect it to the TV via the VGA port, you r other option if the graphics card supports it would be to connect via a HDMI cable and run the TV as a 2nd screen.
May 22, 2014 | Dell Computers & Internet
Picture ok but no sound from tv when I connect laptop to tv via HDMI. Any help?
Simple fix : Click start and type sound and goto "change sound card settings"-> goto HDMI sound (tv icon) and right click it -> select "Set as default" It will work. Just restart the application from which you are trying to play the audio. It will work 1000%
Dec 03, 2012 | Dell Inspiron 1501 Notebook
How do i connect my e6400 laptop to a philips LCD
Assuming you are using Windows XP, here is a link to a Microsoft article outlining how to enable the second monitor. The only thing I would add is that once you get into the properties window, your second monitor may show up darkened out. If it is, you need to right-click on it and select "Attached" before continuing on:
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/monitors.mspx
Mar 01, 2011 | Dell Latitude E6400 Notebook
So I am trying to use a ilo hdmi tv for a secondary monitor on a dell pc. I use a monitor cable with two ends one to the monitor and one to the tv and the tv just shows no signal and the pc does not show...
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket. Also we have "Component Video" marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally. Also we have "Component Video" marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit
Jun 10, 2010 | Televison & Video
I cant connect my laptop to my tv it says no pc signal and goes back to component
Mar 10, 2010 | Televison & Video
I've been trying to use s-video cable to connect
Mar 06, 2010 | Acer Aspire 3690-2196 Notebook
I cant make my e1505 view on my tv do i need to change a setting to tell it where to show?
Feb 07, 2010 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
544 people viewed this question
David Payne
David Payne
