Question about Sony FD Trinitron WEGA KV-SW29M50 29" TV
My TV squeezes picture vertically
My Sony Tv WEGA, Model No. KV-SW 292M50, 2 years old, abrutly squeezed(curved) its picture vertically in both sides (picture color remains the same though images distorted) leaving me nothing to do. I consulted local repairers here just for suggestions on which parts might have failed to function. Their answers mentioned a number of things like horizontal capacitors/transistors, york coil failure etc etc. Actually we don't have a Sony repair Center nearby, and I would like to have a specific idea which parts should I order from the Sony Service Center.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    OK, If I tell you specific parts are damaged then who will replace them? Do you know TV repair?
5 Suggested Answers
SOURCE: Correct overscan on kv-34xbr800
With TV off, enter the following on your remote:
Display > 5 > Volume + > Power now you are in service mode 2 & 5 will take you up and down categories 1 & 4 will take you up and down settings within categories 3 & 6 will change the data up or down
So press 2 until you come to the 2170D_2 category Press 1 until you get to HSIZ and change the data down to the required setting (different data registers for different width settings)
It could be more involved but this might do the trick in your case. Good luck!
Fixatorre
Posted on Mar 24, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Picture Squeezes In On The Sides
Your TV has dry solder joints in "Pin Cushion" area, Its part of Horizontal deflection stage in TV and it requires resold work.
A tech person will understand above technical advise easily.
Need further info, let me know please.
Posted on Sep 30, 2008
jingjao
  • 252 Answers
check the capasitor near the plyback, the value is: from 160volts to 250 volts
Posted on Oct 01, 2008
gopakumarg43
  • 74887 Answers
SOURCE: SONY KV SW 212 M80
Hello
Its pin cushion distortion circut had some trouble with it. There is an Ic and one transistor wich controls the pincushion effect. In most cased the trasistor that fitted on a heat sink, will have loose soldering at its terminals. this transistor will heat up during working, and repeated heating an cooling will make solder terminal loose contacted and it is normal fault. locate this transistor, very near to the LOT, resolder its solder terminals by applying a little more solder. It is best to resolder most of the surrounding solder terminals of high watt resistors, without making any solder bridge in between the solder points. If these does not helps you, replace both the IC [an eight solder terminal one, small IC] and the pin out transsistor described earlier at the same time. this will solve your TVs problem. OK.
Posted on May 22, 2011
SONY KV SW 212 M80 Screen sowing pin cushion distortion. Screen is squeezed on the side and the side is curved inward.
Hello
May 22, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
The left and right sides are black and the picture is squeezed into the middle on the screen. i think it is called pin amp
This problems the Horizontal IC is dead and some of it capacitors too.Might even have the FBT dead too.If still have the same problems,after the "H" IC and those capacitors are replaced.
Sep 09, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The color is fading in our KV-32FV26 Sony Wega The TV is approx 3 years old.
my sont tv model no. KV-XF21M83 (21 in's) indicator lamp flashes red a number of times between 3 secounds interval
the color of the tv has gone faded. The channels name on the top right or left side is not seen properly
The EHT is sparking near the picture tube.
Nessarry guidence may please be comnicated in this regard please. send me feed back to my email adress
sikandher@hotmail.com
Mar 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Tube TV picture
YOU HAVE A VERTICAL DEFLECTION PROBLEM. EITHER SOLDER CONNECTIONS OR THE PUMP UP CAPACITOR.
Nov 20, 2008 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sep 30, 2008 | Sony KV-24FV12 24" TV
Sep 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY KV-XF21M80
maybe the bytes of the memory are not enough for this case^_^
Feb 21, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
What`s seems to be the porblem
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Jan 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-SW29M50 29" TV Logo
57 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
