Question about Dell Latitude E6410 Notebook PC - Intel Core i5 i5-520M Dual-core 2.40 GHz - 3 MB - 14.1" Active Mat (4689011)
Laptop doesn't boot up
I thought at first that the charger was the problem, but even with a new charger it doesn't respond at all when I plug it in. Could this be because the battery was totally depleted?
    Novelist:
    Champion:
  • 233 Answers
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and your Dell Latitude E6410 AC Adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
Posted on Nov 05, 2012
5 Suggested Answers
  • 1584 Answers
SOURCE: Got a new battery now I think it may be the
Does the charger lamp show green when plugged in?? If not charger is faulty.If you had a multi-meter you can check votage output as per the info on the charger.
Posted on Dec 14, 2009
  • 479 Answers
SOURCE: Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Posted on Jan 29, 2009
  • 84 Answers
SOURCE: Hi,i have a Dell Latitude D600 with cant boot with
That could either be a problem with the AC adapter or the motherboard.
You can try updating the firmaware of you motherboard first. Go to this link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
download the BIOS firmware, save it on the desktop then run it. Your computer will reboot while the BIOS is being updated, if you'll have the same problem after that, call Dell to get a replacement for your AC adapter or motherboard.
Posted on Dec 31, 2010
electrotech1
  • 1126 Answers
SOURCE: My laptop is not recognizing
The charger is defective, not putting out enough voltage to operate unit or charge the battery, unit needs replace, check with best buy.
Posted on Jun 07, 2011
Power Button doesn't work
I have a Dell Studio laptop and sometimes some buttons become not responsive, including the power button. As for power button, I noticed that if you hold it for a few seconds, the laptop will turn on (at least in my case). The fix that works for me is as follows:
1. Turn the laptop off;
2. Disconnect the charger and take out the battery;
3. Wait for a few seconds;
4. Open the laptop lid (as you probably closed it while taking out the battery), push the power button and hold it for a few seconds. Nothing will happen as the laptop won't have any power, but it clears some sort of electrostatic load or whatever it's called;
5. Put the battery back in and turn on the laptop.
I used this for a few times, so perhaps it'll help in your case as well.
Feb 05, 2013 | Dell Vostro 1700 Laptop Computer (Intel...
How can I tell if a power surge hit my laptop and ruined it? I can't even get it to boot up
It could either be that the motherboard is fried or the Hard drive has just gotten slightly corrupted. If you have the Windows install disk that came with it you could boot that up and then go into repair mode (press R) and then run "chkdsk /r" this would fix a hard drive issue. However if your laptop will not turn on at all when you press the power button then it is likely dead.
Nov 07, 2012 | Computers & Internet
I have a emachine e528 laptop when I cut my computer on it just shows a blinking white underline in the top left corner how do I fix this?
First things first. Make sure you don't have anything connected in the USB sockets or the bays (CDs etc). Disconnect from the charger and also remove the battery. Hold down the 'on' button for 10 seconds...this will reset your laptop. Reconnect to power and try to switch on again. If the laptop still doesn't function it may be a RAM problem or a hard disc problem (you can try removing and re-installing both). It's worth trying a Windows installation disc to see if the laptop can boot from that. If it can, that will prove your RAM and motherboard is OK and indicate a problem with loading Windows. You don't say whether you get any 'splash' screen....that's the one that usually gives the manufacturers name briefly. If you don't even get that, it could be a bad omen. If you can get the Windows installation disc to boot, you can do a repair installation. To do that you go right through the installation procedure until you get the prompt asking you if you want a new installation or repair installation. This is different from the Repair Console- don't select that. You may find that the installation fails because the hard disc is no good. In that case you will have to transfer your data onto a new disc, there's free software to do that (you will need another laptop or PC)
Sep 26, 2012 | Computers & Internet
Help! My Laptop Acer Aspire One stuck at window logo loading Anyone please, help my acer aspire one stuck at window xp logo loading. I try everthing in F8 button, it didn't work, even in safe mod
oh a fun one. Reset your bios to defaults. if that doesn't work then try a windows disk boot up. if that doesn't work you're screwed.
if you want any of your files from the computer first pull out the hdd buy a cord and transfer them to another computer.
Sep 07, 2012 | Acer Aspire One PC Notebook
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
I have a gateway mp8708 and it wont charge, boot, or even power the charging led. i tested the charger and itd fine. what could be the problem?
One of two things are likely your problem:
1) The battery is so dead that it's preventing any power from reaching the rest of the PC. Try pulling the battery out, plugging the laptop in, and turning it on.
If that doesn't work,
2) The motherboard power converter is burned out. If this is the case, unfortunately you will need a replacement motherboard or a replacement laptop.
Good luck, and hope this is helpful!
May 18, 2011 | Gateway MP8708 Notebook
My laptop is dell inspiron 1525 but battery is not charging i have replaced the battery and even i have used new adapter but i cant solve the problem please help me to fix it
Hi
please remove the battery, plug-in the charger and turn ON the laptop, if it doesn't work,
then the internal part that connects the laptop to the charger have problem and need to be fixed through a technician.
Good Luck
May 13, 2011 | Dell Inspiron 1525 Notebook
Toshiba Tecra 8000 keeps switching itself off.
I'd suggest removing the battery. Most laptops can run directly off the AC adapter. If it will boot up OK without the bad battery, you can either leave it like that, or buy a new battery.
If it won't boot, then you have problems other than the battery.
Feb 08, 2009 | Toshiba Tecra 8000 Notebook
Dell Latitude E6410 Notebook PC - Intel Core i5 i5-520M Dual-core 2.40 GHz - 3 MB - 14.1" Active Mat (4689011) Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
